Aller au contenu principal
Dell Latitude E4310 Display Replacement
Ce dont vous avez besoin
  1. Dell Latitude E4310 Display Replacement, Battery: étape 1, image 1 de 1
    • Power down the laptop and remove all power cords.
  2. Dell Latitude E4310 Display Replacement: étape 2, image 1 de 2 Dell Latitude E4310 Display Replacement: étape 2, image 2 de 2
    • Push in the battery release button with your thumb.
    • Pull up on the battery to remove.
  3. Dell Latitude E4310 Display Replacement, Display: étape 3, image 1 de 3 Dell Latitude E4310 Display Replacement, Display: étape 3, image 2 de 3 Dell Latitude E4310 Display Replacement, Display: étape 3, image 3 de 3
    • Open up the laptop and flatten it down on a workable surface.
    • Turn it around so that the screen is closest to you.
    • Insert the flat end of a spudger, or plastic opening tool, into the groove between the screen bezel and top case.
    • Twist the spudger, or plastic opening tool, until you hear a clicking sound and continue doing this around the entirety of the display.
    • Remove the bezel.
  4. Dell Latitude E4310 Display Replacement: étape 4, image 1 de 2 Dell Latitude E4310 Display Replacement: étape 4, image 2 de 2
    • Remove the six 0.3mm Phillips #1 screws.
  5. Dell Latitude E4310 Display Replacement: étape 5, image 1 de 2 Dell Latitude E4310 Display Replacement: étape 5, image 2 de 2
    • Remove the two 0.5mm Phillips #1 screws.
    • There are two screws located at each corner. Only remove the ones closest to the outer edge.
  6. Dell Latitude E4310 Display Replacement: étape 6, image 1 de 2 Dell Latitude E4310 Display Replacement: étape 6, image 2 de 2
    • Carefully lift the screen up and flip it over onto the keyboard side as if you were turning the page of a book.
  7. Dell Latitude E4310 Display Replacement: étape 7, image 1 de 3 Dell Latitude E4310 Display Replacement: étape 7, image 2 de 3 Dell Latitude E4310 Display Replacement: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    • Use a pair of tweezers to flip the blue tape 180 degrees.
    • By flipping the tape you disconnect the display connector.
  8. Dell Latitude E4310 Display Replacement: étape 8, image 1 de 1
    • Remove the screen from the laptop.
6 autres ont terminé cette réparation.
Aylin
Membre depuis le 02/21/18
309 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 37
Total : 1,637
