Aller au contenu principal
Dell Latitude E5410 keyboard Replacement
Ce dont vous avez besoin
  1. Dell Latitude E5410 keyboard Replacement, Dell Latitude E5410 keyboard: étape 1, image 1 de 1
    • Position laptop so that the LCD screen is aligned directly flat and parallel to the keyboard section of the laptop.
  2. Dell Latitude E5410 keyboard Replacement: étape 2, image 1 de 1
    • Use the iFix it Opening Tool to remove the flat section located directly above the keyboard, as seen in picture.
  3. Dell Latitude E5410 keyboard Replacement: étape 3, image 1 de 1
    • Locate two internal screws (pictured) under removed section.
    • Use the Phillips screwdriver to remove both screws.
    • The screw in the middle is 3.85mm and the screw on the left is 8.66mm.
  4. Dell Latitude E5410 keyboard Replacement: étape 4, image 1 de 1
    • Firmly grip the upper section of the keyboard.
    • Pull on the keyboard in an upwards motion.
    • The keyboard should be successfully removed.
3 autres ont terminé cette réparation.
Megan Perrizo
Membre depuis le 09/29/16
377 Réputation
2 tutoriels rédigés
Équipe
Un commentaire
thanks man but its super easy not moderat i have 16 years old and i remove my keybord...
ZendomXGamer ZXG - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 16
Total : 5,104
