Aller au contenu principal
Dell Latitude E5470 LC-Display Panel Replacement
Ce dont vous avez besoin
  1. Dell Latitude E5470 LC-Display Panel Replacement, Bottom cover removal: étape 1, image 1 de 2 Dell Latitude E5470 LC-Display Panel Replacement, Bottom cover removal: étape 1, image 2 de 2
    • Loosen the 8 screws on the bottom cover. The screws will remain in the casing, they do not come out all the way.
    • Insert the pick or spudger between the upper and lower casing to release the plastic clips.
    • Attention needed: The clips are easily broken.
  2. Dell Latitude E5470 LC-Display Panel Replacement, Disconnect the battery: étape 2, image 1 de 1
    • To disconnect the battery, pull gently upwards on the tab connector.
  3. Dell Latitude E5470 LC-Display Panel Replacement, Remove the LCD Bezel: étape 3, image 1 de 1
    • Using a pick or spudger, gently insert between the LCD back-cover and bezel to release the clips.
    • The bezel is also glued to the LCD panel.
    • Remove slowly to avoid tearing or damaging any components underneath.
  4. Dell Latitude E5470 LC-Display Panel Replacement, Removing the LCD panel: étape 4, image 1 de 1
    • Remove the 4 Philips screws securing the panel.
  5. Dell Latitude E5470 LC-Display Panel Replacement, Remove the LCD Connector: étape 5, image 1 de 3 Dell Latitude E5470 LC-Display Panel Replacement, Remove the LCD Connector: étape 5, image 2 de 3 Dell Latitude E5470 LC-Display Panel Replacement, Remove the LCD Connector: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the LCD paneland lay it flat on the keyboard.
    • You will be able to see the connector on the back of the LCD panel secured with some adhesive tape and a metal connector.
    • Udsing the tweezers, slowly lift the tape away to reveal the blue sticky protector. Removing the blue pad to see the metal connector underneath.
    • Using a spudger, lift the front of the connector up (highlighted by the white arrow).
    • Pull the cable back to release the cable from the connector.
    • To reassemble, follow the steps in reverse.
4 autres ont terminé cette réparation.
Harvey
Membre depuis le 02/15/16
5 381 Réputation
10 tutoriels rédigés
5 commentaires
Your presentation is perfect
sachida1986niit - Réponse
Thanks very much :)
Harvey - Réponse
Hello, will this model with touch screen work with non touch replacement LCD?
cellularcircuit - Réponse
Damaged touch lcd and was not using touch , want to save some $ by installing not touch lcd..
cellularcircuit -
Thanks - seems that little piece of blue sticky protector was my whole problem, months of a flickering screen, that was temporarily fixed upon pressing on the bottom of the bezel. Upon opening up the screen, it was crooked. So I straightened it, put things back together, and the flickering seems to be gone. Cross my fingers!
Peter Lyons - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 63
Total : 8,623
