Introduction
This is a quick four-step guide for the removal and replacement of a Dell Latitude E6330 Keyboard. The keyboard is one of the most crucial parts of the laptop, as without you are a driver without the wheel.
Ce dont vous avez besoin
Start by flipping the laptop over and locate the two screws. (they should be located in a dense on the back of the laptop)
Then use a screwdriver to remove the two, deeply recessed, 2.5mm x 5mm screws from the bottom face of the laptop.
After place the two screws in a safe place as without them you won't have a keyboard brazel to protect the inner systems.
At this time you should be able to gently lift the keyboard off of the frame and expose a ribbon cable connecting it to the motherboard. Flip up the clip holding the ribbon in place and remove the faulty keyboard.
Then place in the new keyboard you've bought and flip down the clip holding the ribbo. To ensure the keybaord is connected to the mother board.
2 autres ont terminé cette réparation.
