Aller au contenu principal
Dell Latitude E6330 Speakers Replacement
Ce dont vous avez besoin
  1. Dell Latitude E6330 Speakers Replacement, Removing Battery and Hard Drive: étape 1, image 1 de 2 Dell Latitude E6330 Speakers Replacement, Removing Battery and Hard Drive: étape 1, image 2 de 2
    • Take out the battery by pulling the tabs.
    • Unscrew 2 screws and remove the hard drive (Phillips Head 1 2.5mm x 5mm).
  2. Dell Latitude E6330 Speakers Replacement, Removing SD Card and DVD Drive: étape 2, image 1 de 2 Dell Latitude E6330 Speakers Replacement, Removing SD Card and DVD Drive: étape 2, image 2 de 2
    • Press and remove the SD card protector.
    • Press and remove the pull tab on DVD Drive.
  3. Dell Latitude E6330 Speakers Replacement, Removing the Backplate: étape 3, image 1 de 3 Dell Latitude E6330 Speakers Replacement, Removing the Backplate: étape 3, image 2 de 3 Dell Latitude E6330 Speakers Replacement, Removing the Backplate: étape 3, image 3 de 3
    • Unscrew the five screws (Phillips Head 1 2.5mm x 5mm).
    • Remove the backplate by pulling from the battery to the front.
  4. Dell Latitude E6330 Speakers Replacement, Removing the Keyboard Bezel: étape 4, image 1 de 3 Dell Latitude E6330 Speakers Replacement, Removing the Keyboard Bezel: étape 4, image 2 de 3 Dell Latitude E6330 Speakers Replacement, Removing the Keyboard Bezel: étape 4, image 3 de 3
    • Remove the track pad wire by carefully pulling up.
    • Flip the laptop over to top.
    • Remove the bezel from the keyboard by prying under the bezel and unclipping it.
    • Pull the bezel from the track pad to the screen to remove it.
    • The wire is fragile, handle with care.
  5. Dell Latitude E6330 Speakers Replacement, Keyboard and Trackpad Removal: étape 5, image 1 de 3 Dell Latitude E6330 Speakers Replacement, Keyboard and Trackpad Removal: étape 5, image 2 de 3 Dell Latitude E6330 Speakers Replacement, Keyboard and Trackpad Removal: étape 5, image 3 de 3
    • Unscrew the three screws (Phillips Head 1 2mm x 3mm).
    • Unclip the keyboard wire harness, then slide the wire towards the screen to remove it.
    • Unclip the trackpad wire harness, sliding the wire towards the front of the laptop to remove it.
    • The wire harnesses are fragile and may break if the user adds too much pressure.
  6. Dell Latitude E6330 Speakers Replacement, Removing LEDs and Screws: étape 6, image 1 de 3 Dell Latitude E6330 Speakers Replacement, Removing LEDs and Screws: étape 6, image 2 de 3 Dell Latitude E6330 Speakers Replacement, Removing LEDs and Screws: étape 6, image 3 de 3
    • Grab the wire harness and pull towards the track pad to remove it.
    • Remove the six screws (Phillips Head 1 2.5mm x 5mm).
    • Remove the two screws (Phillips Head 1 2mm x 3mm).
  7. Dell Latitude E6330 Speakers Replacement, Removing Back-Palmrest Screws: étape 7, image 1 de 1
    • Remove the nine screws labeled P (Phillips Head 1 2.5 x 5mm).
    • Remove the two screws (Phillips Head 1 2 x 3mm).
  8. Dell Latitude E6330 Speakers Replacement, Remove the Palmrest: étape 8, image 1 de 3 Dell Latitude E6330 Speakers Replacement, Remove the Palmrest: étape 8, image 2 de 3 Dell Latitude E6330 Speakers Replacement, Remove the Palmrest: étape 8, image 3 de 3
    • Insert spudger tool into crease of palmrest, prying in a downward motion.
    • Move along the edges of the palmrest, relieving all clips from laptop base.
    • Remove palmrest in a upwards motion.
  9. Dell Latitude E6330 Speakers Replacement, Removing the Speaker Wire: étape 9, image 1 de 3 Dell Latitude E6330 Speakers Replacement, Removing the Speaker Wire: étape 9, image 2 de 3 Dell Latitude E6330 Speakers Replacement, Removing the Speaker Wire: étape 9, image 3 de 3
    • Remove the four screws to the speakers (Phillips Head 1 2.5 x 7mm).
    • Remove the speaker wire harness. Pull towards the track pad to remove it.
    • the wire is fragile, pull with care.
  10. Dell Latitude E6330 Speakers Replacement, Removing the Speakers: étape 10, image 1 de 3 Dell Latitude E6330 Speakers Replacement, Removing the Speakers: étape 10, image 2 de 3 Dell Latitude E6330 Speakers Replacement, Removing the Speakers: étape 10, image 3 de 3
    • Remove or move tape out of the way in order to release the wire.
    • Remove the speakers.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 11
Total : 876
