Aller au contenu principal
Dell Latitude E6400 CPU Replacement
Ce dont vous avez besoin
  1. Dell Latitude E6400 CPU Replacement, Battery Removal: étape 1, image 1 de 3 Dell Latitude E6400 CPU Replacement, Battery Removal: étape 1, image 2 de 3 Dell Latitude E6400 CPU Replacement, Battery Removal: étape 1, image 3 de 3
    • Disconnect AC power adaptor
    • Push battery release tabs inwards.
    • Slide the battery out of the computer.
  2. Dell Latitude E6400 CPU Replacement, Bottom Lid: étape 2, image 1 de 2 Dell Latitude E6400 CPU Replacement, Bottom Lid: étape 2, image 2 de 2
    • Remove the one 7.5 mm Phillips screw securing the bottom case.
    • Pull the bottom lid towards yourself to remove it.
  3. Dell Latitude E6400 CPU Replacement, Fan: étape 3, image 1 de 3 Dell Latitude E6400 CPU Replacement, Fan: étape 3, image 2 de 3 Dell Latitude E6400 CPU Replacement, Fan: étape 3, image 3 de 3
    • Remove the two 4.8mm Phillips screws securing the fan.
    • Disconnect the fan by pulling power cable straight up.
    • Lift the fan with your finger and slide it out towards the inside of the laptop.
  4. Dell Latitude E6400 CPU Replacement, Heat Sink: étape 4, image 1 de 2 Dell Latitude E6400 CPU Replacement, Heat Sink: étape 4, image 2 de 2
    • Remove the four Phillips screws securing the heat sink.
    • Using your finger gently lift and remove heat sink .
  5. Dell Latitude E6400 CPU Replacement: étape 5, image 1 de 1
    • Gently rotate left the locking screw to release CPU from its socket.
    • Lift the CPU straight up of it's socket.
D. K. Labudek
Membre depuis le 03/09/18
685 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 17
Total : 439
