Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
The backplate can crack and expose the hardware it protects. This guide will show the user how to replace the backplate.
Pièces
Aucune pièce spécifiée.
  1. Push the tabs on the left and right of the battery out towards the edge of the case. Push the tabs on the left and right of the battery out towards the edge of the case.
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Push the button in on the CD/DVD drive to eject the drive. Push the button in on the CD/DVD drive to eject the drive.
    • Push the button in on the CD/DVD drive to eject the drive.
  4. Slide the drive out of the laptop. When removing the drive, keep it flat to prevent damage to anything inside the laptop.
    • Slide the drive out of the laptop.
    • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  5. Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop. Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
    • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
    • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  6. Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting. Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
    • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
    • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
4 autre(s) ont terminé cette réparation.
Madysen Eames
Membre depuis le 27/02/2018
1 293 Réputation
7 tutoriels rédigés
Équipe
UMass Dartmouth, Team S2-G3, Simcock Spring 2018 Membre de l'équipe UMass Dartmouth, Team S2-G3, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G3
3 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 27
Total : 464
