Aller au contenu principal
Dell Latitude E6420 CPU Replacement
Ce dont vous avez besoin
  1. Dell Latitude E6420 CPU Replacement, Rear Panel Removal: étape 1, image 1 de 2 Dell Latitude E6420 CPU Replacement, Rear Panel Removal: étape 1, image 2 de 2
    • Remove the eight screws holding down the rear panel using a Phillips #0 Screwdriver. Carefully remove base cover by hand.
  2. Dell Latitude E6420 CPU Replacement, CPU: étape 2, image 1 de 1
    • Remove the battery by pushing the tabs outward, then removing the battery from the device.
  3. Dell Latitude E6420 CPU Replacement: étape 3, image 1 de 1
    • Remove the four screws securing the heatsink using the Phillips #0 screwdriver.
    • Remove the heatsink and fan assembly.
  4. Dell Latitude E6420 CPU Replacement: étape 4, image 1 de 1
    • Use the flat end of a spudger to rotate the lock 180 degrees counterclockwise to unlock the CPU.
  5. Dell Latitude E6420 CPU Replacement: étape 5, image 1 de 2 Dell Latitude E6420 CPU Replacement: étape 5, image 2 de 2
    • Lift the CPU out of the motherboard assembly.
6 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 12
30 derniers jours : 44
Total : 3,675
