Aller au contenu principal
Dell Latitude E6510 Speaker Replacement
Ce dont vous avez besoin
  1. Attention : les étapes 1 à 3 sont issues d'un tutoriel marqué comme étant en cours.
    Dell Latitude E6510 Speaker Replacement, Keyboard: étape 1, image 1 de 3 Dell Latitude E6510 Speaker Replacement, Keyboard: étape 1, image 2 de 3 Dell Latitude E6510 Speaker Replacement, Keyboard: étape 1, image 3 de 3
    • Open the laptop and locate the volume panel on the keyboard.
    • Use the spudger to get underneath the righthand side of the panel and gently pry up the side.
  2. Dell Latitude E6510 Speaker Replacement: étape 2, image 1 de 3 Dell Latitude E6510 Speaker Replacement: étape 2, image 2 de 3 Dell Latitude E6510 Speaker Replacement: étape 2, image 3 de 3
    • Remove the detached volume panel from the keyboard.
    • Locate the two screws holding the keyboard in place. Then Remove these screws with a Philips PH1 head screwdriver.
  3. Dell Latitude E6510 Speaker Replacement: étape 3, image 1 de 3 Dell Latitude E6510 Speaker Replacement: étape 3, image 2 de 3 Dell Latitude E6510 Speaker Replacement: étape 3, image 3 de 3
    • Locate the tab near the back of the keyboard.
    • Pull upwards on the tab to start removing the keyboard and then using both hands at the sides, pull until the keyboard comes free.
  4. Attention : les étapes 4 à 6 sont issues d'un tutoriel marqué comme étant en cours.
    Dell Latitude E6510 Speaker Replacement, Battery: étape 4, image 1 de 1
    • Make sure the device is shutdown
    • Position the laptop upside down with the battery facing towards you.
    • Locate the battery latches circled in red.
  5. Dell Latitude E6510 Speaker Replacement: étape 5, image 1 de 2 Dell Latitude E6510 Speaker Replacement: étape 5, image 2 de 2
    • Gently slide both latches inward until you hear both latches release.
  6. Dell Latitude E6510 Speaker Replacement: étape 6, image 1 de 3 Dell Latitude E6510 Speaker Replacement: étape 6, image 2 de 3 Dell Latitude E6510 Speaker Replacement: étape 6, image 3 de 3
    • Pull the battery towards yourself as shown until completely removed from the computer.
  7. Attention : les étapes 7 à 11 sont issues d'un tutoriel marqué comme étant en cours.
    Dell Latitude E6510 Speaker Replacement, Fan: étape 7, image 1 de 2 Dell Latitude E6510 Speaker Replacement, Fan: étape 7, image 2 de 2
    • Flip over laptop and locate door panel screws.
    • Remove the Screws.
  8. Dell Latitude E6510 Speaker Replacement: étape 8, image 1 de 2 Dell Latitude E6510 Speaker Replacement: étape 8, image 2 de 2
    • Slide and remove the access door.
  9. Dell Latitude E6510 Speaker Replacement: étape 9, image 1 de 2 Dell Latitude E6510 Speaker Replacement: étape 9, image 2 de 2
    • Locate the fan and two fan screws.
    • Remove the 2 screws using a PZ0 Phillip head screwdriver.
  10. Dell Latitude E6510 Speaker Replacement: étape 10, image 1 de 2 Dell Latitude E6510 Speaker Replacement: étape 10, image 2 de 2
    • Using a plastic spudger, gently pry the fan upwards.
    • Once the fan has been loosened, slowly remove the main fan component.
    • Do not pull too hard as their is still a wire attached.
  11. Dell Latitude E6510 Speaker Replacement: étape 11, image 1 de 2 Dell Latitude E6510 Speaker Replacement: étape 11, image 2 de 2
    • Locate the wire holding the fan in place and detach the clip.
  12. Dell Latitude E6510 Speaker Replacement, Speaker: étape 12, image 1 de 3 Dell Latitude E6510 Speaker Replacement, Speaker: étape 12, image 2 de 3 Dell Latitude E6510 Speaker Replacement, Speaker: étape 12, image 3 de 3
    • Remove the hard drive.
    • Pull the drive right and out of the computer.
  13. Dell Latitude E6510 Speaker Replacement: étape 13, image 1 de 1
    • Remove the small battery.
    • Undo the blue circle first.
    • Pull out the end of the cord by the plastic part to avoid damage to the wire.
  14. Dell Latitude E6510 Speaker Replacement: étape 14, image 1 de 3 Dell Latitude E6510 Speaker Replacement: étape 14, image 2 de 3 Dell Latitude E6510 Speaker Replacement: étape 14, image 3 de 3
    • Loosen but do not remove the silver screws surrounding the heat sink using a PZ1 screwhead.
  15. Dell Latitude E6510 Speaker Replacement: étape 15, image 1 de 2 Dell Latitude E6510 Speaker Replacement: étape 15, image 2 de 2
    • Remove the heat sink from the laptop.
  16. Dell Latitude E6510 Speaker Replacement: étape 16, image 1 de 3 Dell Latitude E6510 Speaker Replacement: étape 16, image 2 de 3 Dell Latitude E6510 Speaker Replacement: étape 16, image 3 de 3
    • Push the silver clips on both sides of the memory cards outwards.
    • Gently pull the cards out one at a time.
  17. Dell Latitude E6510 Speaker Replacement: étape 17, image 1 de 3 Dell Latitude E6510 Speaker Replacement: étape 17, image 2 de 3 Dell Latitude E6510 Speaker Replacement: étape 17, image 3 de 3
    • Unscrew the side panels on both sides and slide them off.
  18. Dell Latitude E6510 Speaker Replacement: étape 18, image 1 de 2 Dell Latitude E6510 Speaker Replacement: étape 18, image 2 de 2
    • Remove the screws of the back framework.
  19. Dell Latitude E6510 Speaker Replacement: étape 19, image 1 de 2 Dell Latitude E6510 Speaker Replacement: étape 19, image 2 de 2
    • Loosen the two highlighted screws, do not remove.
  20. Dell Latitude E6510 Speaker Replacement: étape 20, image 1 de 3 Dell Latitude E6510 Speaker Replacement: étape 20, image 2 de 3 Dell Latitude E6510 Speaker Replacement: étape 20, image 3 de 3
    • Undo the cables until the are not attached to the back half of the keyboard.
    • Pull the cables backwards and to the side of the laptop.
  21. Dell Latitude E6510 Speaker Replacement: étape 21, image 1 de 3 Dell Latitude E6510 Speaker Replacement: étape 21, image 2 de 3 Dell Latitude E6510 Speaker Replacement: étape 21, image 3 de 3
    • Undo the other side also.
    • The cables should only be loose, not removed.
  22. Dell Latitude E6510 Speaker Replacement: étape 22, image 1 de 2 Dell Latitude E6510 Speaker Replacement: étape 22, image 2 de 2
    • Partially open the laptop.
    • Side the top half of the laptop backwards towards yourself to undo it from the bottom half.
  23. Dell Latitude E6510 Speaker Replacement: étape 23, image 1 de 3 Dell Latitude E6510 Speaker Replacement: étape 23, image 2 de 3 Dell Latitude E6510 Speaker Replacement: étape 23, image 3 de 3
    • Pry the frame work of the laptop off using a plastic splunger.
    • Proceed slowly, any screws that may have been missed can break your laptop if not removed.
  24. Dell Latitude E6510 Speaker Replacement: étape 24, image 1 de 3 Dell Latitude E6510 Speaker Replacement: étape 24, image 2 de 3 Dell Latitude E6510 Speaker Replacement: étape 24, image 3 de 3
    • Remove the screws from the wireless detector.
    • Remove the detector.
  25. Dell Latitude E6510 Speaker Replacement: étape 25, image 1 de 3 Dell Latitude E6510 Speaker Replacement: étape 25, image 2 de 3 Dell Latitude E6510 Speaker Replacement: étape 25, image 3 de 3
    • Remove the screws from the top and bottom of both speakers.
    • Remove the speakers.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 22
Total : 2,744
