Aller au contenu principal
Dell Latitude E6520 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Latitude E6520 Keyboard Replacement, Battery: étape 1, image 1 de 2 Dell Latitude E6520 Keyboard Replacement, Battery: étape 1, image 2 de 2
    • With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
    • When the latches are unlocked, a small logo resembling an open padlock will become visible.
  2. Dell Latitude E6520 Keyboard Replacement: étape 2, image 1 de 2 Dell Latitude E6520 Keyboard Replacement: étape 2, image 2 de 2
    • Grasp the battery from the top and pull upward.
  3. Dell Latitude E6520 Keyboard Replacement, Bottom Cover: étape 3, image 1 de 2 Dell Latitude E6520 Keyboard Replacement, Bottom Cover: étape 3, image 2 de 2
    • Remove the ten 8.6 mm JIS #0 screws.
  4. Dell Latitude E6520 Keyboard Replacement: étape 4, image 1 de 1
    • Place fingers underneath cover and pull off the cover.
  5. Dell Latitude E6520 Keyboard Replacement, Keyboard: étape 5, image 1 de 3 Dell Latitude E6520 Keyboard Replacement, Keyboard: étape 5, image 2 de 3 Dell Latitude E6520 Keyboard Replacement, Keyboard: étape 5, image 3 de 3
    • Pry off the plastic keyboard trim. It is easiest to start at the bottom of the keyboard.
  6. Dell Latitude E6520 Keyboard Replacement: étape 6, image 1 de 2 Dell Latitude E6520 Keyboard Replacement: étape 6, image 2 de 2
    • Remove the six 3.63 mm JIS #0 screws holding the keyboard in place.
  7. Dell Latitude E6520 Keyboard Replacement: étape 7, image 1 de 2 Dell Latitude E6520 Keyboard Replacement: étape 7, image 2 de 2
    • Lift the keypad up from the bottom.
    • Rest the keypad on the LCD screen for easy access during the next step.
  8. Dell Latitude E6520 Keyboard Replacement: étape 8, image 1 de 2 Dell Latitude E6520 Keyboard Replacement: étape 8, image 2 de 2
    • Peel back the tape holding the ribbon connector.
    • Disconnect the ribbon and the keyboard will be free from the laptop.
Alec Weiss
Membre depuis le 11/05/18
800 Réputation
8 tutoriels rédigés
Équipe
IUPUI, Team S2-G2, Baechle Fall 2018 Membre de l'équipe IUPUI, Team S2-G2, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G2
3 membres
8 tutoriels rédigés
Un commentaire
Hello,
Nice instructions, could someone please tell me what are the other conector/ribbions used for in this dell e6520 under the keyboard ? any help will most appreciated.
Thanks in advance
khalidaafghany - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 19
Total : 1,821
