Aller au contenu principal
Dell Latitude E6530 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Latitude E6530 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Flip the computer over so that the bottom panel is facing you.
  2. Dell Latitude E6530 Hard Drive Replacement: étape 2, image 1 de 2 Dell Latitude E6530 Hard Drive Replacement: étape 2, image 2 de 2
    • Slide the switches away from each other to release the battery.
  3. Dell Latitude E6530 Hard Drive Replacement: étape 3, image 1 de 2 Dell Latitude E6530 Hard Drive Replacement: étape 3, image 2 de 2
    • Using your hands, gently remove the battery from the device.
  4. Dell Latitude E6530 Hard Drive Replacement, Hard Drive: étape 4, image 1 de 2 Dell Latitude E6530 Hard Drive Replacement, Hard Drive: étape 4, image 2 de 2
    • Using a Phillips #00 screwdriver, unscrew the two screws.
  5. Dell Latitude E6530 Hard Drive Replacement: étape 5, image 1 de 2 Dell Latitude E6530 Hard Drive Replacement: étape 5, image 2 de 2
    • Gently remove the hard drive.
  6. Dell Latitude E6530 Hard Drive Replacement: étape 6, image 1 de 1
    • Undo the Phillips #1 screw keeping the drive in the bracket.
  7. Dell Latitude E6530 Hard Drive Replacement: étape 7, image 1 de 1
    • Remove the drive from the bracket,
To reassemble your device, follow these instructions in reverse order. Refer to the troubleshooting guide and additional links for more information if issue persists.
Un commentaire
There’s a missing step here. There’s another screw you’re supposed to undo to remove the drive.
Ella - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 19
Total : 876
