Aller au contenu principal
Dell Latitude E7250 RAM Replacement
Ce dont vous avez besoin
  1. Dell Latitude E7250 RAM Replacement, Battery: étape 1, image 1 de 2 Dell Latitude E7250 RAM Replacement, Battery: étape 1, image 2 de 2
    • Slide the battery release all the way to the right.
    • Once the battery release is pulled all the way, the battery will lift itself slightly from the casing.
    • Remove the battery.
  2. Dell Latitude E7250 RAM Replacement, RAM: étape 2, image 1 de 3 Dell Latitude E7250 RAM Replacement, RAM: étape 2, image 2 de 3 Dell Latitude E7250 RAM Replacement, RAM: étape 2, image 3 de 3
    • With the battery removed two screws will be visible. These will need to be removed.
    • Placing your hands on either side of the panel, push down and pull back to slide the plate back and off.
  3. Dell Latitude E7250 RAM Replacement: étape 3, image 1 de 3 Dell Latitude E7250 RAM Replacement: étape 3, image 2 de 3 Dell Latitude E7250 RAM Replacement: étape 3, image 3 de 3
    • The RAM stick will be located on the left side of the computer.
    • Located on either side of the RAM stick is a pair of metal bars. Gently pull them to the side of the ram and it will lift upwards.
    • Pull the RAM stick gently, at an angle away from the rest of the computer.
3 autres ont terminé cette réparation.
Liliana Mendoza
Membre depuis le 09/25/17
159 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 55
Total : 4,779
