Aller au contenu principal
Dell Latitude E7250 SSD Replacement
Ce dont vous avez besoin
  1. Dell Latitude E7250 SSD Replacement, Battery: étape 1, image 1 de 2 Dell Latitude E7250 SSD Replacement, Battery: étape 1, image 2 de 2
    • Slide the battery release all the way to the right.
    • Once the battery release is pulled all the way, the battery will lift itself slightly from the casing.
    • Remove the battery.
  2. Dell Latitude E7250 SSD Replacement, SSD: étape 2, image 1 de 3 Dell Latitude E7250 SSD Replacement, SSD: étape 2, image 2 de 3 Dell Latitude E7250 SSD Replacement, SSD: étape 2, image 3 de 3
    • With the battery removed two screws will be visible. These will need to be removed.
    • Placing your hands on either side of the panel, push down and pull back to slide the plate back and off.
  3. Dell Latitude E7250 SSD Replacement: étape 3, image 1 de 3 Dell Latitude E7250 SSD Replacement: étape 3, image 2 de 3 Dell Latitude E7250 SSD Replacement: étape 3, image 3 de 3
    • Locate your SSD, it is on the right side and held in with a small screw.
    • Unscrew the SSD carefully. Once done, the SSD will "pop" upwards at an angle making removal easy.
    • Gently grasp the SSD on either side with your thumb and forefinger and pull away from the computer.
7 autres ont terminé cette réparation.
Robert Townsend
Membre depuis le 09/25/17
345 Réputation
2 tutoriels rédigés
Équipe
Un commentaire
Thanks a lot for this !
viperx007 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 31
30 derniers jours : 139
Total : 10,904
