Aller au contenu principal
Dell Latitude E7270 Motherboard Removal
Ce dont vous avez besoin
  1. Dell Latitude E7270 Motherboard Removal, Back Panel: étape 1, image 1 de 1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Motherboard Removal: étape 2, image 1 de 1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Motherboard Removal: étape 3, image 1 de 1
    • Lift and remove the panel.
  4. Dell Latitude E7270 Motherboard Removal, Battery: étape 4, image 1 de 1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Motherboard Removal: étape 5, image 1 de 1
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Motherboard Removal: étape 6, image 1 de 1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 Motherboard Removal, Cooling Fan: étape 7, image 1 de 3 Dell Latitude E7270 Motherboard Removal, Cooling Fan: étape 7, image 2 de 3 Dell Latitude E7270 Motherboard Removal, Cooling Fan: étape 7, image 3 de 3
    • Remove the 4 pin fan power connector from the motherboard by using your finger and pulling up.
    • Remove the four M2.5 X 5MM screws that hold on the rectangular bracket located towards the center of the motherboard using a Phillips #00 screwdriver.
    • Remove the three M2.5 X 5MM screws that hold down the circular fan bracket using a Phillips #00 screwdriver.
  8. Dell Latitude E7270 Motherboard Removal: étape 8, image 1 de 1
    • Lift and remove fan by pulling gently straight up using your fingers
  9. Dell Latitude E7270 Motherboard Removal: étape 9, image 1 de 1
    • Before replacing fan, make sure to place a small amount of thermal paste to ensure proper heat dissipation and long term life.
  10. Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: étape 10, image 1 de 3 Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: étape 10, image 2 de 3 Dell Latitude E7270 Motherboard Removal, Motherboard Replacement: étape 10, image 3 de 3
    • Remove the 10 wire connections by using your fingers to separate the connections.
    • Remove the thirteen M2.5 X 5MM screws that fasten the motherboard using a Phillips #00 screwdriver.
    • Remove the two M2.5 X 8MM external screws that fasten the motherboard from outside using a Phillips #00 screwdriver.
  11. Dell Latitude E7270 Motherboard Removal: étape 11, image 1 de 1
    • Lift and remove the motherboard by grabbing the outside edges and pulling straight up.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 44
Total : 2,823
