Aller au contenu principal
Dell Latitude E7440 RAM Replacement
Ce dont vous avez besoin
  1. Dell Latitude E7440 RAM Replacement, Prepare the laptop: étape 1, image 1 de 1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 RAM Replacement, Release the battery: étape 2, image 1 de 3 Dell Latitude E7440 RAM Replacement, Release the battery: étape 2, image 2 de 3 Dell Latitude E7440 RAM Replacement, Release the battery: étape 2, image 3 de 3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 RAM Replacement, Remove the battery: étape 3, image 1 de 1
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 RAM Replacement, RAM: étape 4, image 1 de 2 Dell Latitude E7440 RAM Replacement, RAM: étape 4, image 2 de 2
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
  5. Dell Latitude E7440 RAM Replacement: étape 5, image 1 de 2 Dell Latitude E7440 RAM Replacement: étape 5, image 2 de 2
    • Slide the base cover down slightly and remove it.
  6. Dell Latitude E7440 RAM Replacement: étape 6, image 1 de 3 Dell Latitude E7440 RAM Replacement: étape 6, image 2 de 3 Dell Latitude E7440 RAM Replacement: étape 6, image 3 de 3
    • For each RAM module, pull apart both the clips and remove the memory.
    • iFixit’s device came without RAM installed. Your device will have a module between each set of clips.
5 autres ont terminé cette réparation.
Akash Kedia
Membre depuis le 01/24/19
1 397 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team S2-G5, White Winter 2019 Membre de l'équipe Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 7
30 derniers jours : 60
Total : 2,608
