Aller au contenu principal
Dell Latitude E7440 Trackpad Replacement
Ce dont vous avez besoin
  1. Dell Latitude E7440 Trackpad Replacement, Trackpad: étape 1, image 1 de 2 Dell Latitude E7440 Trackpad Replacement, Trackpad: étape 1, image 2 de 2
    • Slide the latch and remove the battery.
  2. Dell Latitude E7440 Trackpad Replacement: étape 2, image 1 de 3 Dell Latitude E7440 Trackpad Replacement: étape 2, image 2 de 3 Dell Latitude E7440 Trackpad Replacement: étape 2, image 3 de 3
    • Remove two 3mm screws using the Phillips #0 screwdriver.
    • Slide access door down and remove it by slightly jerking it. Make sure no part of the door is sticking to the components.
  3. Dell Latitude E7440 Trackpad Replacement: étape 3, image 1 de 3 Dell Latitude E7440 Trackpad Replacement: étape 3, image 2 de 3 Dell Latitude E7440 Trackpad Replacement: étape 3, image 3 de 3
    • Remove two 5mm screws using the Phillips #0 screwdriver.
    • Unplug highlighted cable. Be careful not to snap it in half.
  4. Dell Latitude E7440 Trackpad Replacement: étape 4, image 1 de 1
    • Remove the fan from the device.
  5. Dell Latitude E7440 Trackpad Replacement: étape 5, image 1 de 3 Dell Latitude E7440 Trackpad Replacement: étape 5, image 2 de 3 Dell Latitude E7440 Trackpad Replacement: étape 5, image 3 de 3
    • Remove cables on the bottom.
  6. Dell Latitude E7440 Trackpad Replacement: étape 6, image 1 de 3 Dell Latitude E7440 Trackpad Replacement: étape 6, image 2 de 3 Dell Latitude E7440 Trackpad Replacement: étape 6, image 3 de 3
    • Remove the following screws using the Phillips #0 screwdriver.
    • Five 5mm screws.
    • Seven 3mm screws.
    • One 8mm screw.
  7. Dell Latitude E7440 Trackpad Replacement: étape 7, image 1 de 1
    • Remove the keyboard bezel. This might take some effort. Use some force in one direction only.
  8. Dell Latitude E7440 Trackpad Replacement: étape 8, image 1 de 2 Dell Latitude E7440 Trackpad Replacement: étape 8, image 2 de 2
    • Remove the two 2.5mm mouse button screws using the Phillips #0 screwdriver.
    • Remove the mouse button.
  9. Dell Latitude E7440 Trackpad Replacement: étape 9, image 1 de 3 Dell Latitude E7440 Trackpad Replacement: étape 9, image 2 de 3 Dell Latitude E7440 Trackpad Replacement: étape 9, image 3 de 3
    • Remove three 3mm screws using the Phillips #0 screwdriver.
    • Remove the keyboard by pulling it in one direction.
  10. Dell Latitude E7440 Trackpad Replacement: étape 10, image 1 de 3 Dell Latitude E7440 Trackpad Replacement: étape 10, image 2 de 3 Dell Latitude E7440 Trackpad Replacement: étape 10, image 3 de 3
    • Disconnect the cables from the device.
    • Remove a single 5mm screw using the Phillips #0 screwdriver.
    • Remove the trackpad panel.
2 autres ont terminé cette réparation.
Sheetal Prasanna
Membre depuis le 11/06/19
649 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S1-G1, Stella Fall 2019 Membre de l'équipe IUPUI, Team S1-G1, Stella Fall 2019
IUPUI-STELLA-F19S1G1
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 28
Total : 2,850
