Aller au contenu principal
Dell Latitude E7470 Motherboard Replacement
Ce dont vous avez besoin
  1. Dell Latitude E7470 Motherboard Replacement, RAM: étape 1, image 1 de 2 Dell Latitude E7470 Motherboard Replacement, RAM: étape 1, image 2 de 2
    • Grab the two clips beside the RAM stick and pull them outward. The RAM stick should release.
    • Remove the RAM from the device.
    • Repeat this for second RAM stick
  2. Dell Latitude E7470 Motherboard Replacement, Battery: étape 2, image 1 de 1
    • Use the pull tab on the battery connector to lift the connector straight up off its socket on the motherboard, disconnecting it.
  3. Dell Latitude E7470 Motherboard Replacement: étape 3, image 1 de 2 Dell Latitude E7470 Motherboard Replacement: étape 3, image 2 de 2
    • Remove the single 4 mm Phillips screw securing the bottom left corner of the battery.
    • If you are removing an extended capacity battery, remove the Phillips screw securing the bottom right corner of the battery.
  4. Dell Latitude E7470 Motherboard Replacement: étape 4, image 1 de 1
    • Remove the battery from the laptop.
  5. Dell Latitude E7470 Motherboard Replacement, Fan and Heatsink: étape 5, image 1 de 2 Dell Latitude E7470 Motherboard Replacement, Fan and Heatsink: étape 5, image 2 de 2
    • After opening the backcase of the computer, remove the screws using the Phillips #0 screwdriver.
    • Unplug and remove the wire from the socket.
  6. Dell Latitude E7470 Motherboard Replacement: étape 6, image 1 de 1
    • Remove the fan and heatsink from the laptop.
    • Make sure to wipe off the existing thermal paste from the CPU and heatsink with an alcohol-soaked pad and apply a new layer.
  7. Dell Latitude E7470 Motherboard Replacement, Motherboard: étape 7, image 1 de 3 Dell Latitude E7470 Motherboard Replacement, Motherboard: étape 7, image 2 de 3 Dell Latitude E7470 Motherboard Replacement, Motherboard: étape 7, image 3 de 3
    • Remove all the screws using a Phillips #0 screwdriver.
    • Disconnect all of the cables from the motherboard.
  8. Dell Latitude E7470 Motherboard Replacement: étape 8, image 1 de 1
    • Remove the motherboard from the laptop.
2 autres ont terminé cette réparation.
Un commentaire
Good overall, the motherboard screw picture shows too many screws. Also, might need a picture of removing the two side screws for the port cover, and that there are two screws next to the expansion port, under the port cover.
Charles Coburn - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 16
30 derniers jours : 38
Total : 3,631
