Aller au contenu principal
Dell Latitude ST Motherboard Replacement
Ce dont vous avez besoin
  1. Dell Latitude ST Motherboard Replacement, Battery: étape 1, image 1 de 3 Dell Latitude ST Motherboard Replacement, Battery: étape 1, image 2 de 3 Dell Latitude ST Motherboard Replacement, Battery: étape 1, image 3 de 3
    • Locate the back panel tab.
    • Press down on the tab to remove the panel.
  2. Dell Latitude ST Motherboard Replacement: étape 2, image 1 de 3 Dell Latitude ST Motherboard Replacement: étape 2, image 2 de 3 Dell Latitude ST Motherboard Replacement: étape 2, image 3 de 3
    • Using a Phillips #0 screwdriver, remove the four 6mm screws attaching the inside panel to the device.
  3. Dell Latitude ST Motherboard Replacement: étape 3, image 1 de 3 Dell Latitude ST Motherboard Replacement: étape 3, image 2 de 3 Dell Latitude ST Motherboard Replacement: étape 3, image 3 de 3
    • Use the blue plastic opening tool to push in the tab located on the backside of the device.
    • Slide the tool around the edges of the device to unsnap the tabs and pry the frame off.
  4. Dell Latitude ST Motherboard Replacement: étape 4, image 1 de 3 Dell Latitude ST Motherboard Replacement: étape 4, image 2 de 3 Dell Latitude ST Motherboard Replacement: étape 4, image 3 de 3
    • Remove the three 6mm Phillips #0 screws attaching the battery.
  5. Dell Latitude ST Motherboard Replacement: étape 5, image 1 de 3 Dell Latitude ST Motherboard Replacement: étape 5, image 2 de 3 Dell Latitude ST Motherboard Replacement: étape 5, image 3 de 3
    • Using your hands or a plastic opening tool, unplug the white battery cable.
    • Push forward on the top part of the cable to disconnect it from the device.
  6. Dell Latitude ST Motherboard Replacement: étape 6, image 1 de 3 Dell Latitude ST Motherboard Replacement: étape 6, image 2 de 3 Dell Latitude ST Motherboard Replacement: étape 6, image 3 de 3
    • Pull up on the black tab located at the top of the battery to remove the battery from the device.
  7. Dell Latitude ST Motherboard Replacement, Motherboard: étape 7, image 1 de 2 Dell Latitude ST Motherboard Replacement, Motherboard: étape 7, image 2 de 2
    • Remove the 3mm Phillips #0 screw from the SSD drive which is located above the speaker and to the left of the motherboard.
  8. Dell Latitude ST Motherboard Replacement: étape 8, image 1 de 3 Dell Latitude ST Motherboard Replacement: étape 8, image 2 de 3 Dell Latitude ST Motherboard Replacement: étape 8, image 3 de 3
    • Pull up on the white and black cables attached to the WLAN to unplug them.
    • Remove the one 3mm the Phillips #0 screw attached to the WLAN card.
    • Remove the WLAN card.
  9. Dell Latitude ST Motherboard Replacement: étape 9, image 1 de 3 Dell Latitude ST Motherboard Replacement: étape 9, image 2 de 3 Dell Latitude ST Motherboard Replacement: étape 9, image 3 de 3
    • Pull up on the copper tape to loosen it from the screen.
    • Unscrew the seven 6mm the Phillips #0 screws from the base.
  10. Dell Latitude ST Motherboard Replacement: étape 10, image 1 de 2 Dell Latitude ST Motherboard Replacement: étape 10, image 2 de 2
    • Locate the grey LCD cable attached to the motherboad on the device.
    • Pull up the black tape handle attached to the LCD cable to disconnect it.
  11. Dell Latitude ST Motherboard Replacement: étape 11, image 1 de 3 Dell Latitude ST Motherboard Replacement: étape 11, image 2 de 3 Dell Latitude ST Motherboard Replacement: étape 11, image 3 de 3
    • Using your hands or the blue plastic opening tool, go along the edges of the frame and unsnap the screen from the middle frame.
  12. Dell Latitude ST Motherboard Replacement: étape 12, image 1 de 3 Dell Latitude ST Motherboard Replacement: étape 12, image 2 de 3 Dell Latitude ST Motherboard Replacement: étape 12, image 3 de 3
    • Turn over the middle frame.
    • Pull on the white cables with the blue tape to disconnect them.
  13. Dell Latitude ST Motherboard Replacement: étape 13, image 1 de 2 Dell Latitude ST Motherboard Replacement: étape 13, image 2 de 2
    • Flip the middle frame back over.
    • Unplug the three white cables attached to the motherboard.
    • Use the blue plastic opening tool to push down on the cables to disconnect them.
  14. Dell Latitude ST Motherboard Replacement: étape 14, image 1 de 3 Dell Latitude ST Motherboard Replacement: étape 14, image 2 de 3 Dell Latitude ST Motherboard Replacement: étape 14, image 3 de 3
    • Unplug the last motherboard cable attached to the bottom of the frame and the motherboard.
    • With the blue plastic opening tool, flip up the white latch on the top part of the cable.
    • Pull up on the cable using the blue plastic opening tool to disconnect it from the motherboard.
  15. Dell Latitude ST Motherboard Replacement: étape 15, image 1 de 3 Dell Latitude ST Motherboard Replacement: étape 15, image 2 de 3 Dell Latitude ST Motherboard Replacement: étape 15, image 3 de 3
    • Remove the single 6mm screw attaching the motherboard.
    • Remove the Motherboard from the middle frame of the device.
4 autres ont terminé cette réparation.
Addie Kenney
Membre depuis le 04/11/17
413 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 586
