Aller au contenu principal
Dell Latitude ST Speaker Replacement
Ce dont vous avez besoin
  1. Dell Latitude ST Speaker Replacement, Battery: étape 1, image 1 de 3 Dell Latitude ST Speaker Replacement, Battery: étape 1, image 2 de 3 Dell Latitude ST Speaker Replacement, Battery: étape 1, image 3 de 3
    • Locate the back panel tab.
    • Press down on the tab to remove the panel.
  2. Dell Latitude ST Speaker Replacement: étape 2, image 1 de 3 Dell Latitude ST Speaker Replacement: étape 2, image 2 de 3 Dell Latitude ST Speaker Replacement: étape 2, image 3 de 3
    • Using a Phillips #0 screwdriver, remove the four 6mm screws attaching the inside panel to the device.
  3. Dell Latitude ST Speaker Replacement: étape 3, image 1 de 3 Dell Latitude ST Speaker Replacement: étape 3, image 2 de 3 Dell Latitude ST Speaker Replacement: étape 3, image 3 de 3
    • Use the blue plastic opening tool to push in the tab located on the backside of the device.
    • Slide the tool around the edges of the device to unsnap the tabs and pry the frame off.
  4. Dell Latitude ST Speaker Replacement: étape 4, image 1 de 3 Dell Latitude ST Speaker Replacement: étape 4, image 2 de 3 Dell Latitude ST Speaker Replacement: étape 4, image 3 de 3
    • Remove the three 6mm Phillips #0 screws attaching the battery.
  5. Dell Latitude ST Speaker Replacement: étape 5, image 1 de 3 Dell Latitude ST Speaker Replacement: étape 5, image 2 de 3 Dell Latitude ST Speaker Replacement: étape 5, image 3 de 3
    • Using your hands or a plastic opening tool, unplug the white battery cable.
    • Push forward on the top part of the cable to disconnect it from the device.
  6. Dell Latitude ST Speaker Replacement: étape 6, image 1 de 3 Dell Latitude ST Speaker Replacement: étape 6, image 2 de 3 Dell Latitude ST Speaker Replacement: étape 6, image 3 de 3
    • Pull up on the black tab located at the top of the battery to remove the battery from the device.
  7. Dell Latitude ST Speaker Replacement, Speaker: étape 7, image 1 de 3 Dell Latitude ST Speaker Replacement, Speaker: étape 7, image 2 de 3 Dell Latitude ST Speaker Replacement, Speaker: étape 7, image 3 de 3
    • Using your hands or a plastic opening tool, disconnect the white speaker connector from its socket near the bottom of the motherboard.
  8. Dell Latitude ST Speaker Replacement: étape 8, image 1 de 2 Dell Latitude ST Speaker Replacement: étape 8, image 2 de 2
    • Unscrew the 6mm Phillips #0 screw from the left side of the speaker.
    • Unscrew the 3mm Phillips #0 screw from the right side of the speaker.
  9. Dell Latitude ST Speaker Replacement: étape 9, image 1 de 2 Dell Latitude ST Speaker Replacement: étape 9, image 2 de 2
    • Using the plastic opening tool, pry the speaker up to remove it from the device.
Addie Kenney
Membre depuis le 04/11/17
416 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 220
