Aller au contenu principal
Pièces
Aucune pièce spécifiée.
  1. Before removing the battery from the laptop, make sure the power is off.
    • Before removing the battery from the laptop, make sure the power is off.
    • Push both battery locking clips outward at the same time.
  2. Slide the battery out of the laptop.
    • Slide the battery out of the laptop.
  3. Remove the four 4-mm screws on the bottom of the laptop using a #0 screw driver.
    • Remove the four 4-mm screws on the bottom of the laptop using a #0 screw driver.
  4. Carefully turn the laptop over and open the screen all the way. Locate the slot to remove the keyboard in the lower left hand corner.
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  5. After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  6. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  7. Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  8. Remove the flexible ribbon from ZIF connector.
    • Remove the flexible ribbon from ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
  9. Position the laptop so that the bottom is facing upward.
    • Position the laptop so that the bottom is facing upward.
    • Remove the 3 #0 4 mm screws holding the bottom of the palm rest.
  10. Return the laptop to proper position and open the screen.
    • Return the laptop to proper position and open the screen.
    • Remove the 6 #0 4 mm screws holding in the palm rest.
  11. Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
    • Gently lift the palm rest and rotate it outward so that the bottom is now facing up.
    • The ribbon attached to the track is short and extremely delicate. Use care when moving the palm rest.
  12. Lift up on the small ZIF connector and remove ribbon.
    • Lift up on the small ZIF connector and remove ribbon.
    • If ribbon seems stuck gently wiggle it to remove. Do not pull ribbon with great force.
  13. Remove the #00 4 mm screws holding the speakers in place.
    • Remove the #00 4 mm screws holding the speakers in place.
  14. Gently pull the speaker cable out.
    • Gently pull the speaker cable out.
    • If the wire is tight, wiggle it back and forth but don’t apply too much force.
    • Do not use the speaker wire to pull itself out of the connector.
  15. Pull the speakers straight up and out of the laptop.
    • Pull the speakers straight up and out of the laptop.
Elai Fresco
Membre depuis le 20/01/2012
7 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 11-20, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 membres
7 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 884
