Aller au contenu principal
Dell Latitude X300 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Latitude X300 Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Remove the four 4 mm Phillips #0 screws from the bottom of the laptop.
  2. Dell Latitude X300 Keyboard Replacement: étape 2, image 1 de 2 Dell Latitude X300 Keyboard Replacement: étape 2, image 2 de 2
    • Carefully turn the laptop over and open the screen all the way.
    • Locate the slot to remove the keyboard in the lower left hand corner.
    • Using a spudger as a lever, insert it into the slot and gently pry up.
  3. Dell Latitude X300 Keyboard Replacement: étape 3, image 1 de 1
    • After the keyboard pops up, pull it away from the screen just enough to release the tabs.
    • Don’t pull the keyboard out forcefully as there is still a ribbon attached to the laptop.
  4. Dell Latitude X300 Keyboard Replacement: étape 4, image 1 de 1
    • Unlock the ZIF connector on the computer by pushing the two outside tabs toward the screen.
  5. Dell Latitude X300 Keyboard Replacement: étape 5, image 1 de 1
    • Remove the flexible ribbon from the ZIF connector.
    • Do not pull on the ribbon to remove it from the ZIF connector.
Jacob Egorov
Membre depuis le 01/20/12
1 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 11-20, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 11-20, Maness Winter 2012
CPSU-MANESS-W12S11G20
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 1,230
