Introduction
This guide was created for people who may need to replace the RAM for the Dell Optiplex FX 170. Someone may need to replace this component if it isn't working properly or has failed. This is an easy fix with no hazards. One should be familiar with electro-static discharge.
Ce dont vous avez besoin
With the base stand facing upwards, unscrew the 6mm Phillips #2 screw.
Pull the base stand straight up from the device.
Using fingers, push the clips on either side of the RAM. The RAM will pop up at a 45 degree angle when both clips are disengaged.
2 autres ont terminé cette réparation.
