Ce dont vous avez besoin
Lay the Dell Optiplex GX260 down on a clean flat surface with the rear towards you.
Push the oval shaped buttons located on the top and bottom of the PC simultaneously and lift the case straight up.
Identify the optical drive in the case.
Remove the analog audio cable from the optical drive.
Remove the IDE cable form the optical drive by pulling straight up on the orange plastic tab..
Remove the power cable from the optical drive.
5 autres ont terminé cette réparation.
