Introduction
The GX620 has a 3.5 inch floppy disk drive. The back end of the traditional floppy drive contains a port for a standard cable that connects to the motherboard. Also here is a connection for power from the power supply.
Pièces
Aucune pièce nécessaire.
Power down your PC and remove the power cord from the back.
  • Power down your PC and remove the power cord from the back.
Ajouter un commentaire
Press and hold the power button for about 10 seconds, then release.
  • Press and hold the power button for about 10 seconds, then release.
    • This helps drain any remaining power stored in the capacitors, so that you can safely work on the internal components.
  • With the computer standing upright, firmly pull on the tab at the back of the computer.
  • When the side panel pops free, gently pull the panel away from the computer.
  • If you have trouble freeing the side panel from the case, you may need to pull the tab a bit harder.
  • Slide the blue latch downward until the panel can be removed from it's hinges.
  • Gently remove the floppy-drive and power cables from the back of the floppy drive.
  • With a Phillips #1 screwdriver, remove the screws connecting the floppy drive to the drive bay. Set the screws aside in a location where you may use them at a later time.
  • To remove the unconnected floppy drive from the drive bay, slide the drive towards the front of the computer.
Kristina
Membre depuis le 03/09/2014
144 Réputation
7 tutoriels rédigés
Équipe
Pasco Hernando, Team 5-1, Prince Fall 2014 Membre de l'équipe Pasco Hernando, Team 5-1, Prince Fall 2014
PHSC-PRINCE-F14S5G1
10 membres
8 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 3
Total : 879
