Aller au contenu principal
Introduction
Replace the Upper Fan in the computer tower to prevent overheating and computer damage.
Outils
Pièces
Aucune pièce spécifiée.
  1. Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Lay the computer on its side; you will see a blue knob. Turn this knob 90 deg clockwise.
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Slide the panel case forward about 1/2 inch while knob is turned. Lift panel case off computer.
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Remove the large blue cover from the computer. There are no screws or tabs holding it in place. Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
    • Remove the large blue cover from the computer. There are no screws or tabs holding it in place.
  5. Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires. Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
    • Remove the power supply that connects the upper fan to the motherboard. The power supply has black, red, green and yellow wires.
  6. Remove the rubber grommets from the base of the fan. A screwdriver or spudger may be useful. Remove the rubber grommets from the base of the fan. A screwdriver or spudger may be useful.
    • Remove the rubber grommets from the base of the fan. A screwdriver or spudger may be useful.
  7. Pull the upper fan out of the computer.
    • Pull the upper fan out of the computer.
7 autres ont terminé cette réparation.
Tom
Membre depuis le 04/10/2010
829 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 22-4, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 membres
26 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 5,064
