Aller au contenu principal
Dell Photo Printer 540 Case Replacement
Ce dont vous avez besoin
  1. Dell Photo Printer 540 Case Replacement, Case: étape 1, image 1 de 1
    • Rotate the photo printer so that the bottom of the case faces upward.
  2. Dell Photo Printer 540 Case Replacement: étape 2, image 1 de 1
    • Use a Phillips #2 screwdriver to remove the three 5.65 mm screws on the bottom panel of the case in a counter-clockwise fashion.
  3. Dell Photo Printer 540 Case Replacement: étape 3, image 1 de 1
    • Rotate the device so that it is upright again. Under the LCD Panel there is a 9.62 mm screw, unscrew using a Phillips #2 screwdriver.
  4. Dell Photo Printer 540 Case Replacement: étape 4, image 1 de 1
    • Remove the back panel of the case by pulling directly back.
    • Some carefully applied force may be required to remove this part.
  5. Dell Photo Printer 540 Case Replacement: étape 5, image 1 de 1
    • Rotate the photo printer so that the bottom panel faces up once again. Now lift off the bottom panel of the case to access all internal components.
  6. Dell Photo Printer 540 Case Replacement: étape 6, image 1 de 2 Dell Photo Printer 540 Case Replacement: étape 6, image 2 de 2
    • Finally remove the side panel with the ink-cartridge door by holding the right side and pulling backwards with the left side.
    • Caution! The side panel is held in by tabs; don't break these.
Jonathan Mintz
Membre depuis le 04/04/12
11 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 14-7, Forte Spring 2012 Membre de l'équipe Cal Poly, Team 14-7, Forte Spring 2012
CPSU-FORTE-S12S14G7
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 632
