Aller au contenu principal
Dell Precision 5510 Screen Replacement
Ce dont vous avez besoin
  1. Dell Precision 5510 Screen Replacement, Base Cover: étape 1, image 1 de 1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
  2. Dell Precision 5510 Screen Replacement: étape 2, image 1 de 1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Screen Replacement, Battery: étape 3, image 1 de 2 Dell Precision 5510 Screen Replacement, Battery: étape 3, image 2 de 2
    • Unplug the connection that links the battery to the computer.
  4. Dell Precision 5510 Screen Replacement: étape 4, image 1 de 2 Dell Precision 5510 Screen Replacement: étape 4, image 2 de 2
    • Remove the four 4.0 mm JIS #0 screws surrounding the battery.
  5. Dell Precision 5510 Screen Replacement: étape 5, image 1 de 2 Dell Precision 5510 Screen Replacement: étape 5, image 2 de 2
    • Carefully remove the battery from the computer.
  6. Dell Precision 5510 Screen Replacement, Screen: étape 6, image 1 de 2 Dell Precision 5510 Screen Replacement, Screen: étape 6, image 2 de 2
    • Remove the six 4.0 mm Phillips #1 screws.
  7. Dell Precision 5510 Screen Replacement: étape 7, image 1 de 2 Dell Precision 5510 Screen Replacement: étape 7, image 2 de 2
    • Unscrew the one 4.0 mm Phillips #1 screw from the WiFi chip, then remove it.
  8. Dell Precision 5510 Screen Replacement: étape 8, image 1 de 2 Dell Precision 5510 Screen Replacement: étape 8, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Disconnect the black wire. Use tweezers to help.
  9. Dell Precision 5510 Screen Replacement: étape 9, image 1 de 2 Dell Precision 5510 Screen Replacement: étape 9, image 2 de 2
    • Disconnect the multi wire. Use tweezers to help.
  10. Dell Precision 5510 Screen Replacement: étape 10, image 1 de 2 Dell Precision 5510 Screen Replacement: étape 10, image 2 de 2
    • Remove the 1.0 mm Phillips #1 screw.
  11. Dell Precision 5510 Screen Replacement: étape 11, image 1 de 2 Dell Precision 5510 Screen Replacement: étape 11, image 2 de 2
    • Flip the laptop over, so it is sitting in the normal upright position. Hold onto the screen, and pull the keyboard up and away from the screen.
Atlanta Phelps
Membre depuis le 08/28/18
400 Réputation
3 tutoriels rédigés
Équipe
IUPUI, Team S1-G5, Arle Fall 2018 Membre de l'équipe IUPUI, Team S1-G5, Arle Fall 2018
IUPUI-ARLE-F18S1G5
3 membres
6 tutoriels rédigés
Un commentaire
Can I just change the LCD? Or is changing the entire display assembly the only option?
John Gaines - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 15
Total : 3,987
