Aller au contenu principal
Dell Precision 7560 Motherboard Replacement
Ce dont vous avez besoin
  1. Dell Precision 7560 Motherboard Replacement, Battery: étape 1, image 1 de 3 Dell Precision 7560 Motherboard Replacement, Battery: étape 1, image 2 de 3 Dell Precision 7560 Motherboard Replacement, Battery: étape 1, image 3 de 3
    • The screws holding the back cover in place can not be removed.
    • Use a Phillips #0 screwdriver to loosen the the eight 5 mm captive screws in the bottom cover.
    • Remove the back cover by lifting at the corners.
  2. Dell Precision 7560 Motherboard Replacement: étape 2, image 1 de 3 Dell Precision 7560 Motherboard Replacement: étape 2, image 2 de 3 Dell Precision 7560 Motherboard Replacement: étape 2, image 3 de 3
    • Unscrew and remove the five 2 mm screws that secure the battery.
    • Locate the battery connector.
  3. Dell Precision 7560 Motherboard Replacement: étape 3, image 1 de 3 Dell Precision 7560 Motherboard Replacement: étape 3, image 2 de 3 Dell Precision 7560 Motherboard Replacement: étape 3, image 3 de 3
    • Pull the connector towards you to disconnect it.
    • Use your fingers or a plastic opening tool to pry the battery up and remove it from the laptop.
  4. Dell Precision 7560 Motherboard Replacement, Fan: étape 4, image 1 de 2 Dell Precision 7560 Motherboard Replacement, Fan: étape 4, image 2 de 2
    • The screws holding the fan in place cannot be fully removed.
    • Loosen the eight captive screws that secure the fan assembly.
    • Each screw is numbered in the order that they should be loosened.
  5. Dell Precision 7560 Motherboard Replacement: étape 5, image 1 de 2 Dell Precision 7560 Motherboard Replacement: étape 5, image 2 de 2
    • Locate connector cable and pull lightly to remove.
  6. Dell Precision 7560 Motherboard Replacement: étape 6, image 1 de 2 Dell Precision 7560 Motherboard Replacement: étape 6, image 2 de 2
    • Gently pull the first fan connector from the head until it is removed.
    • The thin wire is prone to damage. Exercise extra caution during removal.
  7. Dell Precision 7560 Motherboard Replacement: étape 7, image 1 de 2 Dell Precision 7560 Motherboard Replacement: étape 7, image 2 de 2
    • Gently pull the second fan connector from the head until it is removed.
  8. Dell Precision 7560 Motherboard Replacement: étape 8, image 1 de 2 Dell Precision 7560 Motherboard Replacement: étape 8, image 2 de 2
    • Lifting from the bottom, carefully remove the laptop's fans.
  9. Dell Precision 7560 Motherboard Replacement, Solid-State Drive (SSD): étape 9, image 1 de 2 Dell Precision 7560 Motherboard Replacement, Solid-State Drive (SSD): étape 9, image 2 de 2
    • Unscrew and remove the two 3 mm screws that secure the solid-state drive.
  10. Dell Precision 7560 Motherboard Replacement: étape 10, image 1 de 2 Dell Precision 7560 Motherboard Replacement: étape 10, image 2 de 2
    • Remove the top cover of the Solid State Drive by lifting up from the corners.
    • Notice that the Solid State Drive is located underneath the cover.
    • Pull the Solid State Drive gently towards you from its exposed end to disconnect it.
    • With an appropriate replacement part, exchange the old SSD with a new one.
  11. Dell Precision 7560 Motherboard Replacement, Motherboard: étape 11, image 1 de 3 Dell Precision 7560 Motherboard Replacement, Motherboard: étape 11, image 2 de 3 Dell Precision 7560 Motherboard Replacement, Motherboard: étape 11, image 3 de 3
    • Remove the 5 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
    • Lift to remove the metal overlay.
    • Disconnect the wires attached to the Wi-Fi card.
    • Lift from the sides to remove the Wi-Fi card.
  12. Dell Precision 7560 Motherboard Replacement: étape 12, image 1 de 2 Dell Precision 7560 Motherboard Replacement: étape 12, image 2 de 2
    • Remove the 2 mm screws holding the metal frame in place using a Phillips #0 screwdriver.
    • Remove, carefully and completely, any wires running over the frame.
    • Grab securely and lift to remove the metal frame.
  13. Dell Precision 7560 Motherboard Replacement: étape 13, image 1 de 2 Dell Precision 7560 Motherboard Replacement: étape 13, image 2 de 2
    • Flip up the metal edge holding down the SD connection.
    • Gently pull to disconnect the connecting strip.
  14. Dell Precision 7560 Motherboard Replacement: étape 14, image 1 de 3 Dell Precision 7560 Motherboard Replacement: étape 14, image 2 de 3 Dell Precision 7560 Motherboard Replacement: étape 14, image 3 de 3
    • Remove the 5 mm screw holding the metal cap over the wire connection using a Phillips #0 screwdriver.
    • Holding the sides, lift to remove the metal cap.
    • Lift to disconnect the wire bundle.
  15. Dell Precision 7560 Motherboard Replacement: étape 15, image 1 de 3 Dell Precision 7560 Motherboard Replacement: étape 15, image 2 de 3 Dell Precision 7560 Motherboard Replacement: étape 15, image 3 de 3
    • Using a Phillips #0 screwdriver, remove the eight 2 mm screws holding the motherboard.
    • Flip the motherboard over, exposing the underside.
    • Pull to disconnect the wires leading to the speaker unit.
  16. Dell Precision 7560 Motherboard Replacement: étape 16, image 1 de 1
    • Using both hands, securely lift and remove the motherboard.
Khadija
Membre depuis le 02/08/24
133 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 8
30 derniers jours : 25
Total : 70
