Aller au contenu principal
Dell Precision 7560 Screen Replacement
Ce dont vous avez besoin
  1. Dell Precision 7560 Screen Replacement, Screen: étape 1, image 1 de 3 Dell Precision 7560 Screen Replacement, Screen: étape 1, image 2 de 3 Dell Precision 7560 Screen Replacement, Screen: étape 1, image 3 de 3
    • Using an opener tool, pry open the bezel, following along the screen's perimeter.
    • Lightly pull from the corners to remove the bezel.
  2. Dell Precision 7560 Screen Replacement: étape 2, image 1 de 2 Dell Precision 7560 Screen Replacement: étape 2, image 2 de 2
    • Use the Phillips #0 screwdriver to remove:
    • Two 2 mm screws from the top screen brackets.
    • Two 3 mm screws from the bottom screen brackets.
    • Once these screws are removed, you should be able to gently pry the laptop screen free.
    • Be careful not to apply too much pressure, as this could damage the screen or other components inside the laptop.
  3. Dell Precision 7560 Screen Replacement: étape 3, image 1 de 3 Dell Precision 7560 Screen Replacement: étape 3, image 2 de 3 Dell Precision 7560 Screen Replacement: étape 3, image 3 de 3
    • To fully disconnect the screen, gently peel off the white tape that secures the video connector.
    • Remove the blue tape that lies between the white tape and the video connector.
    • Open the video connector's bracket and remove the cable, pulling towards the back of the device.
Laisha
Membre depuis le 02/14/23
205 Réputation
2 tutoriels rédigés
Équipe
Utah Tech University, Team 1-1, McMurrin Spring 2023 Membre de l'équipe Utah Tech University, Team 1-1, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G1
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 26
30 derniers jours : 65
Total : 1,061
