Aller au contenu principal
Dell Precision M3800 Fan Replacement
Ce dont vous avez besoin
  1. Dell Precision M3800 Fan Replacement, Back Cover: étape 1, image 1 de 2 Dell Precision M3800 Fan Replacement, Back Cover: étape 1, image 2 de 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 Fan Replacement: étape 2, image 1 de 1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 Fan Replacement, Fan: étape 3, image 1 de 2 Dell Precision M3800 Fan Replacement, Fan: étape 3, image 2 de 2
    • Use a Phillips #00 screwdriver to unscrew the two 3.5mm screws that are holding the fans in place.
  4. Dell Precision M3800 Fan Replacement: étape 4, image 1 de 3 Dell Precision M3800 Fan Replacement: étape 4, image 2 de 3 Dell Precision M3800 Fan Replacement: étape 4, image 3 de 3
    • Using a nonmetal prying tool, unplug the cord connecting the fan to the motherboard.
    • If replacing the right fan, this cord is located underneath the fan.
    • If replacing the left fan, this cord is located on the left of the fan.
  5. Dell Precision M3800 Fan Replacement: étape 5, image 1 de 2 Dell Precision M3800 Fan Replacement: étape 5, image 2 de 2
    • Use nonmetal prying tool to lift the bottom of the fan from the laptop body (this will require some force and you will hear an adhesive pulling sound).
    • Repeat the steps for the second fan if needed .
3 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 7
30 derniers jours : 16
Total : 1,268
