Aller au contenu principal
Dell Precision M3800 Speaker Replacement
Ce dont vous avez besoin
  1. Dell Precision M3800 Speaker Replacement, Back Cover: étape 1, image 1 de 2 Dell Precision M3800 Speaker Replacement, Back Cover: étape 1, image 2 de 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 Speaker Replacement: étape 2, image 1 de 1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 Speaker Replacement, Battery: étape 3, image 1 de 1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  4. Dell Precision M3800 Speaker Replacement, Speaker: étape 4, image 1 de 2 Dell Precision M3800 Speaker Replacement, Speaker: étape 4, image 2 de 2
    • Unplug the red, white, and blue speaker wire connected to the main motherboard.
  5. Dell Precision M3800 Speaker Replacement: étape 5, image 1 de 2 Dell Precision M3800 Speaker Replacement: étape 5, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the four 2 mm screws.
  6. Dell Precision M3800 Speaker Replacement: étape 6, image 1 de 2 Dell Precision M3800 Speaker Replacement: étape 6, image 2 de 2
    • Remove the speakers by gently pulling up on the main unit on the left hand side. Make sure to not lose the rubber bushings that are attached to the sides of the speakers.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 8
Total : 395
