Aller au contenu principal
Dell Precision M3800 Touch Pad Replacement
Ce dont vous avez besoin
  1. Dell Precision M3800 Touch Pad Replacement, Back Cover: étape 1, image 1 de 2 Dell Precision M3800 Touch Pad Replacement, Back Cover: étape 1, image 2 de 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a T5 Torx screwdriver to unscrew the ten 3mm screws on the laptop back cover.
    • iFixit’s magnetic project mat is great for keeping the screws in one place.
    • Lift up the silver cover from the back panel to reveal two screws.
    • Use a Phillips screwdriver to remove the two screws underneath the silver cover.
  2. Dell Precision M3800 Touch Pad Replacement: étape 2, image 1 de 1
    • Use an opening tool to pry around the edges of the back panel to loosen the panel.
    • Remove the back panel.
  3. Dell Precision M3800 Touch Pad Replacement, Battery: étape 3, image 1 de 1
    • Disconnect the battery cable from the system board [1].
    • Use a Phillips screwdriver to remove the four screws securing the battery to the laptop.
    • Lift the battery off the computer [2].
  4. Dell Precision M3800 Touch Pad Replacement, Touch Pad: étape 4, image 1 de 3 Dell Precision M3800 Touch Pad Replacement, Touch Pad: étape 4, image 2 de 3 Dell Precision M3800 Touch Pad Replacement, Touch Pad: étape 4, image 3 de 3
    • Remove the wire that connects the touch pad with the motherboard with a hooked pry tool (Spudger 3) and by pulling the pull tab to safely remove the wire.
  5. Dell Precision M3800 Touch Pad Replacement: étape 5, image 1 de 2 Dell Precision M3800 Touch Pad Replacement: étape 5, image 2 de 2
    • Use a Phillips #00 screwdriver to remove the two 2mm silver screws.
  6. Dell Precision M3800 Touch Pad Replacement: étape 6, image 1 de 1
    • Remove the touch pad from the laptop. If needed, use a prying tool to remove the touch pad.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 21
Total : 987
