Aller au contenu principal
Dell Precision M4400 Memory Module Replacement
Ce dont vous avez besoin
  1. Dell Precision M4400 Memory Module Replacement, Battery: étape 1, image 1 de 1
    • Slide the battery release latches to the open position. (The latches lock into place).
    • Grip the battery and slide it out of the battery bay.
  2. Dell Precision M4400 Memory Module Replacement, Base Cover: étape 2, image 1 de 1
    • Loosen the M2.5 x 5-mm captive screw.
    • Using the rubber feet for leverage, slide the bottom of the base assembly toward the front of the computer 1/8th inch, then lift to remove it.
  3. Dell Precision M4400 Memory Module Replacement, Memory Module: étape 3, image 1 de 1
    • To remove the DIMM module, spread away the retaining clips from the side edges of the memory module and lift the free edge of the module so that it sits at about a 30-degree angle to the system board.
    • Grasp the module at the side edges and pull it straight away from the connector. Place the module into anti-static packaging such as an anti- static bag.
Johnathan Hammond
Membre depuis le 02/28/18
44 953 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 986 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 6
Total : 422
