Pièces
Aucune pièce nécessaire.
Slide the battery release latch and remove the battery.
  • Slide the battery release latch and remove the battery.
Ajouter un commentaire
Remove the two M2 x 3-mm screws.
  • Remove the two M2 x 3-mm screws.
  • Slide the cover toward the front of the computer to release the tabs from the base assembly.
  • Remove the cover from the base assembly.
  • Loosen the two captive screws on the HDD1 carrier, and remove the carrier.
  • Push in, then pull up on the safety loop to remove the cover.
    • Use the pull tab to disconnect the HDD1 from the connector on the system board, and remove the HDD1 from the computer.
  • Remove the two M3 x 3-mm screws that secure the pull tab to the HDD1.
  • Set the pull tab aside to use with the replacement HDD1.
  • Remove the two M3 x 3-mm screws that secure the carrier to the computer.
  • Pull up on the pull tab to remove the carrier.
  • Remove the two M3 x 3-mm screws that secure the carrier to the HDD2.
  • Remove the carrier from the HDD2. If your computer does not have an HDD2, remove the hard drive place-holder from the carrier.
  • Remove the interposer from the HDD2 or the place-holder, and set the interposer aside.
Johnathan Hammond
Membre depuis le 28/02/2018
35 317 Réputation
408 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
917 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 30
Total : 134
