Aller au contenu principal
Dell Precision M6400 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Precision M6400 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Slide the battery release latch and remove the battery.
  2. Dell Precision M6400 Hard Drive Replacement, Base Cover: étape 2, image 1 de 1
    • Remove the two M2 x 3-mm screws.
    • Slide the cover toward the front of the computer to release the tabs from the base assembly.
    • Remove the cover from the base assembly.
  3. Dell Precision M6400 Hard Drive Replacement, Hard Drive: étape 3, image 1 de 1
    • Loosen the two captive screws on the HDD1 carrier, and remove the carrier.
    • Push in, then pull up on the safety loop to remove the cover.
    • Use the pull tab to disconnect the HDD1 from the connector on the system board, and remove the HDD1 from the computer.
  4. Dell Precision M6400 Hard Drive Replacement: étape 4, image 1 de 1
    • Remove the two M3 x 3-mm screws that secure the pull tab to the HDD1.
    • Set the pull tab aside to use with the replacement HDD1.
  5. Dell Precision M6400 Hard Drive Replacement: étape 5, image 1 de 1
    • Remove the two M3 x 3-mm screws that secure the carrier to the computer.
    • Pull up on the pull tab to remove the carrier.
  6. Dell Precision M6400 Hard Drive Replacement: étape 6, image 1 de 1
    • Remove the two M3 x 3-mm screws that secure the carrier to the HDD2.
    • Remove the carrier from the HDD2. If your computer does not have an HDD2, remove the hard drive place-holder from the carrier.
    • Remove the interposer from the HDD2 or the place-holder, and set the interposer aside.
Johnathan Hammond
Membre depuis le 02/28/18
44 953 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 29
Total : 4,113
