Aller au contenu principal
Dell Precision M6600 Hard Drive Replacement
Ce dont vous avez besoin
  1. Dell Precision M6600 Hard Drive Replacement, Battery: étape 1, image 1 de 1
    • Slide the lock key to unlock the battery. Then you can lift the battery from its holder.
  2. Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: étape 2, image 1 de 2 Dell Precision M6600 Hard Drive Replacement, Remove Bottom Cover: étape 2, image 2 de 2
    • Using Phillips screwdriver, remove 2 screws holding case.
    • Slide case towards back of laptop then lift off to remove.
  3. Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: étape 3, image 1 de 2 Dell Precision M6600 Hard Drive Replacement, Remove the Hard Drive: étape 3, image 2 de 2
    • Using a Phillips Screwdriver, remove the 4 screws that hold the hard drive in place.
    • Using a Phillips #00 take out the 1.5mm screw then slide to unlock the SSD holder.
  4. Dell Precision M6600 Hard Drive Replacement: étape 4, image 1 de 1
    • When the lock was slid, a medal holder popped out and that is where the SSD is hidden.
4 autres ont terminé cette réparation.
Kaley lindsay
Membre depuis le 03/23/18
582 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G3, Valliere Spring 2018 Membre de l'équipe UMass Dartmouth, Team S8-G3, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G3
2 membres
4 tutoriels rédigés
Un commentaire
How do you remove the bottom? Instructions only show removal of battery then next step shows full access to bottom of laptop? My slide switch doesn’t release the door, any thoughts?
Jason Zuehlke - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 11
30 derniers jours : 30
Total : 3,571
