Aller au contenu principal
Dell Precision M6600 LCD Replacement
Ce dont vous avez besoin
  1. Dell Precision M6600 LCD Replacement, LCD: étape 1, image 1 de 1
    • Open the laptop lid fully and place it on a stable surface to access the screen.
    • Make sure the laptop is unplugged and the battery is removed to prevent electrical hazards.
  2. Dell Precision M6600 LCD Replacement: étape 2, image 1 de 2 Dell Precision M6600 LCD Replacement: étape 2, image 2 de 2
    • Use the iFixit opening tool to carefully pry around the edges of the screen bezel, starting from a corner or along the bottom edge. Gently work around the perimeter to release each of the clips.
    • Once it has been loosened, lift the bezel away from the display and set it aside in a safe place to prevent any damage.
  3. Dell Precision M6600 LCD Replacement: étape 3, image 1 de 1
    • Use a Phillips #0 screwdriver to remove the screws securing the LCD screen to the display frame.
    • Once all screws are removed, set them aside in a safe place.
  4. Dell Precision M6600 LCD Replacement: étape 4, image 1 de 1
    • Carefully disconnect the gold LCD cable from the back of the screen by gently pulling on only the connector, not the cable itself.
    • LCD connectors are fragile. apply gentle, even pressure when disconnecting to avoid bending or breaking the pins.
    • Once the cable is fully detached, lift the LCD screen out of the display assembly and place it on a clean, flat surface to prevent scratches or damage.
Once you have installed the new LCD and reassembled the device, power on your laptop to test the display. If the screen functions correctly, your repair is successful. If you experience issues, double-check connections to ensure everything is securely attached.
Kaley lindsay
Membre depuis le 03/23/18
582 Réputation
4 tutoriels rédigés
Équipe
UMass Dartmouth, Team S8-G3, Valliere Spring 2018 Membre de l'équipe UMass Dartmouth, Team S8-G3, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G3
2 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 19
Total : 1,043
