Aller au contenu principal
Dell Streak 10 Pro Speakers Replacement
Ce dont vous avez besoin
  1. Dell Streak 10 Pro Speakers Replacement, Battery: étape 1, image 1 de 3 Dell Streak 10 Pro Speakers Replacement, Battery: étape 1, image 2 de 3 Dell Streak 10 Pro Speakers Replacement, Battery: étape 1, image 3 de 3
    • Place the device flat on its screen.
    • Using the plastic opening tools, pry open the top segment of the tablet where the camera is located.
    • Take the segment off and place it to the side.
  2. Dell Streak 10 Pro Speakers Replacement: étape 2, image 1 de 2 Dell Streak 10 Pro Speakers Replacement: étape 2, image 2 de 2
    • Remove four 4mm Phillips #0 screws.
  3. Dell Streak 10 Pro Speakers Replacement: étape 3, image 1 de 2 Dell Streak 10 Pro Speakers Replacement: étape 3, image 2 de 2
    • Using the plastic opening tool, lift off the entire back screen of the tablet.
  4. Dell Streak 10 Pro Speakers Replacement: étape 4, image 1 de 3 Dell Streak 10 Pro Speakers Replacement: étape 4, image 2 de 3 Dell Streak 10 Pro Speakers Replacement: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Disconnect the no-fuss ribbon cable connector.
    • The best way is to safely pull the white connector straight out of the socket. Using the tweezers, pull out the white connector that contains the red, green, blue, and black cords connected to it.
    • Remove the battery by gently lifting it out of the device.
  5. Dell Streak 10 Pro Speakers Replacement, SD Card Breakout Board: étape 5, image 1 de 2 Dell Streak 10 Pro Speakers Replacement, SD Card Breakout Board: étape 5, image 2 de 2
    • Remove three 4mm Phillips #0 screws.
  6. Dell Streak 10 Pro Speakers Replacement: étape 6, image 1 de 2 Dell Streak 10 Pro Speakers Replacement: étape 6, image 2 de 2
    • Gently lift up the black covered wire and place it on the side, so that it is not in the way of the procedure.
  7. Dell Streak 10 Pro Speakers Replacement: étape 7, image 1 de 3 Dell Streak 10 Pro Speakers Replacement: étape 7, image 2 de 3 Dell Streak 10 Pro Speakers Replacement: étape 7, image 3 de 3
    • When encountering a zero insertion force connector, the best way it to carefully use tweezers to flip up the white locking flap securing the blue-tipped ribbon cable.
    • Then, gently use the tweezers to pull out the blue-tipped ribbon cable from the unlatched connector.
  8. Dell Streak 10 Pro Speakers Replacement: étape 8, image 1 de 1
    • Use two fingers and gently pull the SD card breakout board from its space.
  9. Dell Streak 10 Pro Speakers Replacement, Speakers: étape 9, image 1 de 3 Dell Streak 10 Pro Speakers Replacement, Speakers: étape 9, image 2 de 3 Dell Streak 10 Pro Speakers Replacement, Speakers: étape 9, image 3 de 3
    • There are five ribbon cables in a row that must be disconnected.
    • Using the tweezers, carefully pull out the first cable straight out of the no-fuss ribbon cable connector.
  10. Dell Streak 10 Pro Speakers Replacement: étape 10, image 1 de 2 Dell Streak 10 Pro Speakers Replacement: étape 10, image 2 de 2
    • Using the tweezers, carefully pull out the cable straight out of the no-fuss ribbon cable connector.
  11. Dell Streak 10 Pro Speakers Replacement: étape 11, image 1 de 2 Dell Streak 10 Pro Speakers Replacement: étape 11, image 2 de 2
    • When dealing with a zero insertion force connector, the best way it to carefully use a tweezer to flip up the white locking flap holding the blue-tipped ribbon cable.
    • Then, gently remove the ribbon cable from the socket.
  12. Dell Streak 10 Pro Speakers Replacement: étape 12, image 1 de 2 Dell Streak 10 Pro Speakers Replacement: étape 12, image 2 de 2
    • When dealing with a zero insertion force connector, the best way it to carefully use a tweezer to flip up the white locking flap holding the blue tip wire.
    • Then gently remove the wire from the socket.
  13. Dell Streak 10 Pro Speakers Replacement: étape 13, image 1 de 3 Dell Streak 10 Pro Speakers Replacement: étape 13, image 2 de 3 Dell Streak 10 Pro Speakers Replacement: étape 13, image 3 de 3
    • Carefully remove the adhesive tapes using the tweezers.
  14. Dell Streak 10 Pro Speakers Replacement: étape 14, image 1 de 3 Dell Streak 10 Pro Speakers Replacement: étape 14, image 2 de 3 Dell Streak 10 Pro Speakers Replacement: étape 14, image 3 de 3
    • Using the tweezers, carefully flip up the locking tab on the Zero Insertion Force connector.
    • Then, gently disconnect the orange ribbon cable.
  15. Dell Streak 10 Pro Speakers Replacement: étape 15, image 1 de 1
    • After removing all the adhesive strips, gently lift up the sensor board as to not bend it.
  16. Dell Streak 10 Pro Speakers Replacement: étape 16, image 1 de 3 Dell Streak 10 Pro Speakers Replacement: étape 16, image 2 de 3 Dell Streak 10 Pro Speakers Replacement: étape 16, image 3 de 3
    • When dealing with a zero insertion force connector, the best way it to carefully use a tweezer to flip up the white locking flap holding the orange ribbon cable.
    • Once the white tab is lifted, use the tweezer to carefully pull out the orange ribbon cable.
  17. Dell Streak 10 Pro Speakers Replacement: étape 17, image 1 de 2 Dell Streak 10 Pro Speakers Replacement: étape 17, image 2 de 2
    • Using your fingers, wiggle the speaker until it comes free from the device. Carefully remove it from the tablet.
  18. Dell Streak 10 Pro Speakers Replacement: étape 18, image 1 de 2 Dell Streak 10 Pro Speakers Replacement: étape 18, image 2 de 2
    • Using your fingers, wiggle the other speaker until it comes free. Carefully remove it from the tablet.
  19. Dell Streak 10 Pro Speakers Replacement: étape 19, image 1 de 1
    • Carefully pull out the connected speakers.
Matthew Ko
Membre depuis le 02/05/19
440 Réputation
2 tutoriels rédigés
Équipe
UC Davis, Team S20-G7, Lore Winter 2019 Membre de l'équipe UC Davis, Team S20-G7, Lore Winter 2019
UCD-LORE-W19S20G7
2 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 127
