Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Pièces
Aucune pièce spécifiée.
  1. Slide the battery release latch to the side.
    • Slide the battery release latch to the side.
    • Slide the battery out of the battery bay.
  2. Loosen the seven captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
    • Loosen the seven captive screws on the base cover and lift the cover off the computer at an angle as shown in the figure.
  3. Kits pour Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Remove the two screws on the hard drive assembly.
    • Remove the two screws on the hard drive assembly.
  5. Pull the pull tab to disconnect the hard drive assembly from the system board connector.
    • Pull the pull tab to disconnect the hard drive assembly from the system board connector.
    • Pull the interposer to detach it from the hard drive.
    • Remove the four screws (two on either side) to detach the hard drive cage from the hard drive.
    • Lift the hard drive cage off the hard drive.
Johnathan Hammond
Membre depuis le 28/02/2018
36 530 Réputation
408 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
18 membres
1 816 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 77
