Pièces
Aucune pièce nécessaire.
Slide the battery release latch until it clicks into place.
  • Slide the battery release latch until it clicks into place.
  • Slide the battery out of the battery bay.
Ajouter un commentaire
Turn the computer over and open the display.
  • Turn the computer over and open the display.
  • Ease the keyboard surround up using your fingers or a plastic scribe.
  • Lift the keyboard surround off the computer.
  • Remove the two screws at the top of the keyboard.
  • CAUTION: The keycaps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Be careful when removing and handling the keyboard.
  • Carefully slide the keyboard out of the computer and turn it over as indicated in the following illustration.
  • CAUTION: Be extremely careful when removing and handling the keyboard. Failure to do so could result in scratching the display panel.
  • Release the keyboard cable connector latch and disconnect the keyboard cable from the system board connector.
  • For backlit keyboards, release the keyboard backlight cable connector latch to disconnect the keyboard backlight cable from the system board connector.
  • Lift the keyboard off the computer.
  • Remove the four screws securing the hard drive assembly to the computer base.
  • Pull the black pull-tab to lift the hard drive assembly out of the computer base and disconnect the interposer from the SATA connector on the system board.
  • Remove the four screws securing the hard drive cage to the hard drive.
  • Pull the interposer to disconnect it from the hard drive.
  • Lift the hard drive off the hard drive cage.
Johnathan Hammond
Membre depuis le 28/02/2018
35 317 Réputation
408 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
917 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 33
