Aller au contenu principal
Dell Studio 1555 Back Panel Removal
Ce dont vous avez besoin
  1. Dell Studio 1555 Back Panel Removal, Battery: étape 1, image 1 de 1
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
  2. Dell Studio 1555 Back Panel Removal: étape 2, image 1 de 3 Dell Studio 1555 Back Panel Removal: étape 2, image 2 de 3 Dell Studio 1555 Back Panel Removal: étape 2, image 3 de 3
    • Slide the locking switch to the left to release the battery.
  3. Dell Studio 1555 Back Panel Removal: étape 3, image 1 de 1
    • Gently pull the battery away from the device.
  4. Dell Studio 1555 Back Panel Removal, Back Panel: étape 4, image 1 de 3 Dell Studio 1555 Back Panel Removal, Back Panel: étape 4, image 2 de 3 Dell Studio 1555 Back Panel Removal, Back Panel: étape 4, image 3 de 3
    • Loosen the three 5mm screws from the back panel using the # 1 Philips screwdriver.
    • The three 5mm screws will stay in place on the back panel.
  5. Dell Studio 1555 Back Panel Removal: étape 5, image 1 de 1
    • Carefully remove the separated back panel.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are unscrewed all the way before attempting again.
2 autres ont terminé cette réparation.
Josh Boone
Membre depuis le 10/10/16
586 Réputation
4 tutoriels rédigés
Équipe
Sam Houston State, Team 12-3, Blackburne Fall 2016 Membre de l'équipe Sam Houston State, Team 12-3, Blackburne Fall 2016
SHSU-BLACKBURNE-F16S12G3
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 576
