Aller au contenu principal
Dell Studio 1555 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Studio 1555 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Turn off and unplug the laptop.
    • Failure to properly turn off device before handling the battery could result in electrical shock.
    • Flip the laptop so the underside is facing up with the battery closest to you.
  2. Dell Studio 1555 Keyboard Replacement: étape 2, image 1 de 3 Dell Studio 1555 Keyboard Replacement: étape 2, image 2 de 3 Dell Studio 1555 Keyboard Replacement: étape 2, image 3 de 3
    • Slide the locking switch to the left to release the battery.
  3. Dell Studio 1555 Keyboard Replacement: étape 3, image 1 de 1
    • Gently pull the battery away from the device.
  4. Dell Studio 1555 Keyboard Replacement, Keyboard: étape 4, image 1 de 1
    • Remove the single 3mm screw underneath the battery with a #1 Phillips screw driver, which holds the media control cover.
  5. Dell Studio 1555 Keyboard Replacement: étape 5, image 1 de 2 Dell Studio 1555 Keyboard Replacement: étape 5, image 2 de 2
    • Flip the laptop over and flatten it out as much as possible.
    • Unsnap the media control cover from the laptop starting nearest to the display.
  6. Dell Studio 1555 Keyboard Replacement: étape 6, image 1 de 2 Dell Studio 1555 Keyboard Replacement: étape 6, image 2 de 2
    • Remove the two 3mm screws with a #1 Phillips screwdriver, holding down the keyboard.
  7. Dell Studio 1555 Keyboard Replacement: étape 7, image 1 de 1
    • Slowly lift the keyboard away from the base.
    • If you pull to hard you risk breaking the keyboard cable connector from the motherboard.
  8. Dell Studio 1555 Keyboard Replacement: étape 8, image 1 de 3 Dell Studio 1555 Keyboard Replacement: étape 8, image 2 de 3 Dell Studio 1555 Keyboard Replacement: étape 8, image 3 de 3
    • Flip up the black tab on the keyboard ZIF connector and unplug the cable.
  9. Dell Studio 1555 Keyboard Replacement: étape 9, image 1 de 1
    • Remove the keyboard
2 autres ont terminé cette réparation.
Hunter Tuck
Membre depuis le 10/10/16
214 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team 12-3, Blackburne Fall 2016 Membre de l'équipe Sam Houston State, Team 12-3, Blackburne Fall 2016
SHSU-BLACKBURNE-F16S12G3
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 966
