Aller au contenu principal
Dell Venue 11 Pro Motherboard Replacement
Ce dont vous avez besoin
  1. Dell Venue 11 Pro Motherboard Replacement, Battery: étape 1, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement, Battery: étape 1, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement, Battery: étape 1, image 3 de 3
    • Turn your device over to the backside. On the notch at the bottom portion of the tablet, use your fingers to lift up the back cover.
  2. Dell Venue 11 Pro Motherboard Replacement: étape 2, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 2, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 2, image 3 de 3
    • Below the battery pack, there are two lock mechanisms. Push EACH lock to the LEFT until it makes a click noise. Lift the battery from the bottom up and remove.
  3. Dell Venue 11 Pro Motherboard Replacement, Frame: étape 3, image 1 de 2 Dell Venue 11 Pro Motherboard Replacement, Frame: étape 3, image 2 de 2
    • Use your Philips #000 screwdriver to unscrew the fourteen 2.5 mm screws marked on the tablet.
    • These screws are extremely small. Place the screws aside in a container or on your magnetic mat to prevent accidental loss.
  4. Dell Venue 11 Pro Motherboard Replacement: étape 4, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 4, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 4, image 3 de 3
    • Slide the cover on the two middle ribbon cables out to remove it. It should uncover the orange cable connectors.
  5. Dell Venue 11 Pro Motherboard Replacement: étape 5, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 5, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 5, image 3 de 3
    • To disconnect the left ribbon cable from the motherboard, place the flat end of your spudger under the edge of the pop connector and pry the connector straight up.
    • The two ribbon cables connect the keyboard attachment ports to the motherboard. Damage to either cables can induce problems with the Dell mobile keyboard.
  6. Dell Venue 11 Pro Motherboard Replacement: étape 6, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 6, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 6, image 3 de 3
    • The right ribbon cable has a ZIF connector. Use the flat end of your spudger to lift up the small locking flap, then pull out the cable.
    • Pulling the ribbon cable out before unlocking the connector can potentially damage the cable.
  7. Dell Venue 11 Pro Motherboard Replacement: étape 7, image 1 de 1
    • There are adhesive strips between the device and the two ribbon cables we disconnected. Pull each cable away from the device just enough to break the adhesive bonds.
  8. Dell Venue 11 Pro Motherboard Replacement: étape 8, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 8, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 8, image 3 de 3
    • Use your pin punch driver to push into the hole on the sim card, then pull out the sim tray.
  9. Dell Venue 11 Pro Motherboard Replacement: étape 9, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 9, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 9, image 3 de 3
    • Insert your plastic opening tool between the screen and frame, and run the tool around the edges to separate the frame from the tablet.
  10. Dell Venue 11 Pro Motherboard Replacement, Mini HDMI Port: étape 10, image 1 de 1
    • Identify the location of the HDMI Port, which will be in the left bottom part of the tablet.
    • If you are replacing the motherboard by itself, then skip step 14.
  11. Dell Venue 11 Pro Motherboard Replacement: étape 11, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 11, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 11, image 3 de 3
    • Wedge the tip of the plastic spudger in between the ZIF connector lock and flip up the lock. Pull the ribbon cable out.
  12. Dell Venue 11 Pro Motherboard Replacement: étape 12, image 1 de 2 Dell Venue 11 Pro Motherboard Replacement: étape 12, image 2 de 2
    • Use your fingers to lift up and take out the mini HDMI board.
  13. Dell Venue 11 Pro Motherboard Replacement, Speakers: étape 13, image 1 de 1
    • Locate the right and left speakers to be replaced. For this guide, we will start with the left speaker, then the right speaker.
    • If you are replacing the motherboard by itself, then skip steps 17 and 19.
  14. Dell Venue 11 Pro Motherboard Replacement: étape 14, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 14, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 14, image 3 de 3
    • Using a pair of tweezers, detach the red and white cable connector from the circuit board.
    • The laptop is rotated 130 degrees counterclockwise for better viewing.
  15. Dell Venue 11 Pro Motherboard Replacement: étape 15, image 1 de 2 Dell Venue 11 Pro Motherboard Replacement: étape 15, image 2 de 2
    • Once the cable has been detached, use your fingers to lift the right speaker upwards to remove it.
  16. Dell Venue 11 Pro Motherboard Replacement: étape 16, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 16, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 16, image 3 de 3
    • On the right side, use a pair of tweezers to detach the red and white cables from the connector.
    • This device is rotated 130 degrees clockwise for better viewing.
  17. Dell Venue 11 Pro Motherboard Replacement: étape 17, image 1 de 1
    • Lift the right speaker upwards using your fingers to remove it.
  18. Dell Venue 11 Pro Motherboard Replacement, USB Port: étape 18, image 1 de 1
    • Start by removing the top ZIF USB ribbon connector
    • If you are replacing the motherboard by itself, then skip steps 23, 24, and 25.
  19. Dell Venue 11 Pro Motherboard Replacement: étape 19, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 19, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 19, image 3 de 3
    • To remove the ribbon cable, move the black retainer upwards. Then pull the ribbon cable rearwards to remove it.
  20. Dell Venue 11 Pro Motherboard Replacement: étape 20, image 1 de 1
    • You must then remove the ribbon cable connected to the USB port located here.
  21. Dell Venue 11 Pro Motherboard Replacement: étape 21, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 21, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 21, image 3 de 3
    • Using a Philips #000 screwdriver remove the two 2.5 mm screws indicated.
  22. Dell Venue 11 Pro Motherboard Replacement: étape 22, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 22, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 22, image 3 de 3
    • Using a pair of tweezers disconnect the connector from the circuit board
  23. Dell Venue 11 Pro Motherboard Replacement: étape 23, image 1 de 2 Dell Venue 11 Pro Motherboard Replacement: étape 23, image 2 de 2
    • After disconnecting all the pieces, remove the USB port circuit board with your fingers
  24. Dell Venue 11 Pro Motherboard Replacement, Motherboard: étape 24, image 1 de 1
    • This is the tablet with its mini HDMI, speakers, and USB port removed. If you only want to replace your motherboard then all previous components will be disconnected from the board but will remain on the tablet.
    • You must first disconnect the ribbon cable highlighted here.
  25. Dell Venue 11 Pro Motherboard Replacement: étape 25, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 25, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 25, image 3 de 3
    • Use the pointy end of your spudger to lift up the ZIF lock. Afterwards, pull the ribbon cable rearwards to disconnect it.
  26. Dell Venue 11 Pro Motherboard Replacement: étape 26, image 1 de 1
    • Now you must disconnect the small battery wire located here on the device.
  27. Dell Venue 11 Pro Motherboard Replacement: étape 27, image 1 de 2 Dell Venue 11 Pro Motherboard Replacement: étape 27, image 2 de 2
    • To disconnect the wire, use the tweezers to grab a hold of it and pull rearwards.
  28. Dell Venue 11 Pro Motherboard Replacement: étape 28, image 1 de 1
  29. Dell Venue 11 Pro Motherboard Replacement: étape 29, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 29, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 29, image 3 de 3
    • Use the tweezers again to grab hold of the black coaxial connector and pull upwards to disconnect.
  30. Dell Venue 11 Pro Motherboard Replacement: étape 30, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 30, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 30, image 3 de 3
    • Now remove the black cable from the motherboard with you fingers.
  31. Dell Venue 11 Pro Motherboard Replacement: étape 31, image 1 de 2 Dell Venue 11 Pro Motherboard Replacement: étape 31, image 2 de 2
    • Now remove the white coaxial connector using the tweezers to pull the connector upwards.
  32. Dell Venue 11 Pro Motherboard Replacement: étape 32, image 1 de 2 Dell Venue 11 Pro Motherboard Replacement: étape 32, image 2 de 2
    • Next simply move the white wire away from the motherboard using your fingers.
  33. Dell Venue 11 Pro Motherboard Replacement: étape 33, image 1 de 1
    • Now turn your attention to the two ZIF connectors at the top. The left ribbon cable connects to the webcam, the right ribbon cable connects to the back camera.
  34. Dell Venue 11 Pro Motherboard Replacement: étape 34, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 34, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 34, image 3 de 3
    • To remove the right ribbon cable, use the pointy end of your spudger to flip the black ZIF lock upwards. Then pull the ribbon cable rearwards to disconnect it.
  35. Dell Venue 11 Pro Motherboard Replacement: étape 35, image 1 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 35, image 2 de 3 Dell Venue 11 Pro Motherboard Replacement: étape 35, image 3 de 3
    • To remove the left ribbon cable, use the pointy end of your spudger to flip the black ZIF retainer into the up position. Then simply pull it rearwards to remove it.
  36. Dell Venue 11 Pro Motherboard Replacement: étape 36, image 1 de 2 Dell Venue 11 Pro Motherboard Replacement: étape 36, image 2 de 2
    • Finally the motherboard can be lifted out by hand.
6 autres ont terminé cette réparation.
Tom Nguyen
Membre depuis le 09/28/17
1 277 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S3-G1, Nance Fall 2017 Membre de l'équipe USF Tampa, Team S3-G1, Nance Fall 2017
USFT-NANCE-F17S3G1
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 33
Total : 4,869
