Aller au contenu principal
Dell Vostro 1320 Fan Replacement
Ce dont vous avez besoin
  1. Dell Vostro 1320 Fan Replacement, Fan: étape 1, image 1 de 2 Dell Vostro 1320 Fan Replacement, Fan: étape 1, image 2 de 2
    • Turn the laptop over so that the bottom of it is exposed.
    • The section of the computer that we need to access is the right panel. You need to start by using the J00 bit attachment to the Bit Driver to unscrew the screw
  2. Dell Vostro 1320 Fan Replacement: étape 2, image 1 de 3 Dell Vostro 1320 Fan Replacement: étape 2, image 2 de 3 Dell Vostro 1320 Fan Replacement: étape 2, image 3 de 3
    • Use the flat Metal Spudger to open the plastic panel.
    • If the panel does not open right away try placing the flat Metal Spudger to the adjacent or opposite side of the plastic panel.
  3. Dell Vostro 1320 Fan Replacement: étape 3, image 1 de 1
    • Unplug the wire connecting the fan to the computer by pulling straight up on the connector.
  4. Dell Vostro 1320 Fan Replacement: étape 4, image 1 de 2 Dell Vostro 1320 Fan Replacement: étape 4, image 2 de 2
    • Remove the two black screws holding the fan down by using the phillips head screwdriver.
  5. Dell Vostro 1320 Fan Replacement: étape 5, image 1 de 2 Dell Vostro 1320 Fan Replacement: étape 5, image 2 de 2
    • Gently pull the fan away from the side of the computer. Lift it out completely.
    • At this point you can now blow all the dust out of your fan and the copper heatsink.
2 autres ont terminé cette réparation.
Christie Lloyd
Membre depuis le 08/26/15
431 Réputation
4 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 15
Total : 679
