Aller au contenu principal
Dell Vostro 1400 RAM Replacement
Ce dont vous avez besoin
  1. Dell Vostro 1400 RAM Replacement, Battery: étape 1, image 1 de 1
    • Be sure the power is off and all cables are unplugged from the device before starting.
    • After flipping over the laptop, the battery is on the bottom side of the laptop.
    • Find the tabs on both the left and right side of the battery.
  2. Dell Vostro 1400 RAM Replacement: étape 2, image 1 de 1
    • Push tabs toward the outside of the laptop until they lock in place.
  3. Dell Vostro 1400 RAM Replacement: étape 3, image 1 de 2 Dell Vostro 1400 RAM Replacement: étape 3, image 2 de 2
    • Push the battery forward to eject it from the laptop.
  4. Dell Vostro 1400 RAM Replacement, RAM: étape 4, image 1 de 2 Dell Vostro 1400 RAM Replacement, RAM: étape 4, image 2 de 2
    • Make sure the laptop is turned off and all cables are unplugged.
    • Loosen the three 3 mm screws on the RAM cover.
    • Screws will not completely come out.
    • Lift the cover and remove it from the laptop.
  5. Dell Vostro 1400 RAM Replacement: étape 5, image 1 de 2 Dell Vostro 1400 RAM Replacement: étape 5, image 2 de 2
    • Pull tabs apart on both the top and bottom of the memory card.
    • Lift memory card and remove it from the laptop.
    • Repeat the process for the second memory card.
David Hogg
Membre depuis le 03/20/17
727 Réputation
5 tutoriels rédigés
Équipe
Texas Tech, Team S8-G2, Bennett Spring 2017 Membre de l'équipe Texas Tech, Team S8-G2, Bennett Spring 2017
TTU-BENNETT-S17S8G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 384
