Pièces
Aucune pièce nécessaire.
Slide the release latch to release the battery [1].
  • Slide the release latch to release the battery [1].
  • Remove the battery from the computer [2].
Ajouter un commentaire
Remove the M2L3 screw that secures the optical drive to the computer [1].
  • Remove the M2L3 screw that secures the optical drive to the computer [1].
    • Using a plastic scribe, push the tab in the direction of the arrow indicated on the chassis. [2].
      • Slide the optical drive out of the computer [3].
  • Using a plastic scribe, release the five tabs from the slots located above the keyboard [1].
    • Flip the keyboard on the palm rest to access the keyboard connector cable under the keyboard [2].
  • Disconnect the keyboard cable from the system board.
    • Remove the keyboard from the computer.
  • Disconnect the optical drive connector and lift it to remove it from the system board [1].
    • Remove the M2L5 screws that secure the base cover [2].
  • Flip the computer and remove the screws (8 screws - M2.5L8; 3 screws - M2L2; 2 screws- M2L2) that secure the base cover to the computer.
  • Use a scribe to pry the edges of the base cover [1].
    • Lift the base cover and remove it from the computer [2].
  • Pull the clips securing the memory module until the memory module pops up [1].
    • Remove the memory module from the system board [2].
Johnathan Hammond
Membre depuis le 28/02/2018
35 317 Réputation
408 tutoriels rédigés
Équipe
Informative Technologies Inc. Membre de l'équipe Informative Technologies Inc.
Community
15 membres
917 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 6
