Aller au contenu principal
Dell Vostro 15 3565 Memory Module Replacement
Ce dont vous avez besoin
  1. Dell Vostro 15 3565 Memory Module Replacement, Battery: étape 1, image 1 de 1
    • Slide the release latch to unlock the battery [1].
    • Remove the battery from the computer [2].
  2. Dell Vostro 15 3565 Memory Module Replacement, Optical-Disk Drive: étape 2, image 1 de 1
    • Remove the screw that secures the optical drive to the computer [1].
    • Using a plastic scribe push the tab to release the optical drive [2].
    • Slide the optical drive out of the computer [3].
  3. Dell Vostro 15 3565 Memory Module Replacement, KeyBoard: étape 3, image 1 de 1
    • Release the keyboard by prying on the keyboard release tabs by using a scribe.
  4. Dell Vostro 15 3565 Memory Module Replacement: étape 4, image 1 de 1
    • Slide and lift the keyboard to access the keyboard connector cable under the keyboard [1,2].
  5. Dell Vostro 15 3565 Memory Module Replacement: étape 5, image 1 de 1
    • Disconnect the keyboard cable from the system board [1].
    • Lift the keyboard cable to remove it from the computer [2].
  6. Dell Vostro 15 3565 Memory Module Replacement, Base Cover: étape 6, image 1 de 1
    • Disconnect the optical drive connector and lift it to remove it from the system board [1,2]
    • Remove the screws inside the palmrest [3].
  7. Dell Vostro 15 3565 Memory Module Replacement: étape 7, image 1 de 1
    • Remove the screws that secure the base cover to the computer [1].
    • Pry the edges of base cover and lift it to remove it from computer [2].
  8. Dell Vostro 15 3565 Memory Module Replacement, Memory Module: étape 8, image 1 de 1
    • Pull the clips securing the memory module until the memory module pops up [1].
    • Remove the memory module from the system board [2].
Johnathan Hammond
Membre depuis le 02/28/18
45 034 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
42 membres
1 989 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 107
