Aller au contenu principal
Dell Vostro 15 KeyBoard Replacement
Ce dont vous avez besoin
  1. Dell Vostro 15 KeyBoard Replacement, Battery: étape 1, image 1 de 1
    • Slide the battery release latches until they click into place.
    • Slide the battery out of the battery bay.
  2. Dell Vostro 15 KeyBoard Replacement, Hinge Cover: étape 2, image 1 de 1
    • Open the display all the way so that it rests flat on your work surface.
    • NOTICE: To avoid damage to the hinge cover, do not lift the cover on both sides simultaneously.
    • Insert a plastic scribe into the indent to lift the hinge cover on the right side.
    • Moving from right to left, ease the hinge cover up, then remove it and set it aside.
  3. Dell Vostro 15 KeyBoard Replacement, KeyBoard: étape 3, image 1 de 1
    • Remove the two M2.5 x 5-mm screws at the top of the keyboard.
    • NOTICE: The key caps on the keyboard are fragile, easily dislodged, and time-consuming to replace. Exercise care when removing and handling the keyboard.
    • Lift the keyboard and hold it up and slightly forward to access to the keyboard connector.
    • Rotate the keyboard connector latch upward to release the keyboard cable.
    • Slide the keyboard cable out of the keyboard connector.
Johnathan Hammond
Membre depuis le 02/28/18
45 237 Réputation
408 tutoriels rédigés
Équipe
RampUP America, Inc. Membre de l'équipe RampUP America, Inc.
Community
43 membres
1 985 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 14
Total : 517
