Aller au contenu principal
Dell Vostro 1500 Keyboard Replacement
Ce dont vous avez besoin
  1. Dell Vostro 1500 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Make certain the power is off.
  2. Dell Vostro 1500 Keyboard Replacement: étape 2, image 1 de 1
    • Press and slide the buttons inward.
  3. Dell Vostro 1500 Keyboard Replacement: étape 3, image 1 de 1
    • Slide the battery away from the computer.
  4. Dell Vostro 1500 Keyboard Replacement: étape 4, image 1 de 1
    • Remove the battery from the slot.
  5. Dell Vostro 1500 Keyboard Replacement, Keyboard: étape 5, image 1 de 3 Dell Vostro 1500 Keyboard Replacement, Keyboard: étape 5, image 2 de 3 Dell Vostro 1500 Keyboard Replacement, Keyboard: étape 5, image 3 de 3
    • Pry the top panel up from the tab in the upper right hand corner.
    • Run your finger under the panel from right to left to pop it loose.
    • You might have to tilt back the screen if you are having trouble popping it loose.
  6. Dell Vostro 1500 Keyboard Replacement: étape 6, image 1 de 2 Dell Vostro 1500 Keyboard Replacement: étape 6, image 2 de 2
    • Unscrew the two Phillips head screws.
  7. Dell Vostro 1500 Keyboard Replacement: étape 7, image 1 de 2 Dell Vostro 1500 Keyboard Replacement: étape 7, image 2 de 2
    • Carefully lift the keyboard away from the computer.
    • Pull the keyboard toward the screen.
    • Do not pull too hard on the keyboard as the connector could be damaged.
  8. Dell Vostro 1500 Keyboard Replacement: étape 8, image 1 de 3 Dell Vostro 1500 Keyboard Replacement: étape 8, image 2 de 3 Dell Vostro 1500 Keyboard Replacement: étape 8, image 3 de 3
    • Lift the blue plastic cover so that is at a 90 degree angle to the keyboard to remove the connection to the keyboard.
  9. Dell Vostro 1500 Keyboard Replacement: étape 9, image 1 de 1
    • Pull the connector toward the screen.
2 autres ont terminé cette réparation.
Daniel Roskuski
Membre depuis le 10/19/16
219 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-3, Catania Fall 2016 Membre de l'équipe UMass Dartmouth, Team 1-3, Catania Fall 2016
UMASSD-CATANIA-F16S1G3
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 4
30 derniers jours : 7
Total : 965
