Aller au contenu principal
Dell Vostro 1700 RAM Replacement
Ce dont vous avez besoin
  1. Dell Vostro 1700 RAM Replacement, Keyboard: étape 1, image 1 de 3 Dell Vostro 1700 RAM Replacement, Keyboard: étape 1, image 2 de 3 Dell Vostro 1700 RAM Replacement, Keyboard: étape 1, image 3 de 3
    • Use the Plastic Opening Tools to pry off the tab located on the right side of the top face plate.
  2. Dell Vostro 1700 RAM Replacement: étape 2, image 1 de 1
    • Lift the plate off the laptop from right to left.
    • Pull the plate out and remove it.
  3. Dell Vostro 1700 RAM Replacement: étape 3, image 1 de 2 Dell Vostro 1700 RAM Replacement: étape 3, image 2 de 2
    • Remove the four 3mm Phillips #0 screws.
  4. Dell Vostro 1700 RAM Replacement: étape 4, image 1 de 2 Dell Vostro 1700 RAM Replacement: étape 4, image 2 de 2
    • Grasp the laptop with both hands as shown.
    • Push the keyboard upwards with your thumbs to disconnect it.
  5. Dell Vostro 1700 RAM Replacement: étape 5, image 1 de 2 Dell Vostro 1700 RAM Replacement: étape 5, image 2 de 2
    • Lift the keyboard from the laptop and remove it.
    • Ensure the connector is fully disconnected before lifting the keyboard out.
  6. Dell Vostro 1700 RAM Replacement, RAM: étape 6, image 1 de 3 Dell Vostro 1700 RAM Replacement, RAM: étape 6, image 2 de 3 Dell Vostro 1700 RAM Replacement, RAM: étape 6, image 3 de 3
    • Dislodge the RAM from its slot.
    • Push the retaining clips outward with your fingers.
  7. Dell Vostro 1700 RAM Replacement: étape 7, image 1 de 3 Dell Vostro 1700 RAM Replacement: étape 7, image 2 de 3 Dell Vostro 1700 RAM Replacement: étape 7, image 3 de 3
    • Pull the RAM chip up and out.
  8. Dell Vostro 1700 RAM Replacement: étape 8, image 1 de 3 Dell Vostro 1700 RAM Replacement: étape 8, image 2 de 3 Dell Vostro 1700 RAM Replacement: étape 8, image 3 de 3
    • Flip the laptop so under side is facing upwards.
    • Remove the 4.5mm Phillips #1 screw from the RAM cover.
    • Lift off the cover.
  9. Dell Vostro 1700 RAM Replacement: étape 9, image 1 de 2 Dell Vostro 1700 RAM Replacement: étape 9, image 2 de 2
    • Dislodge the RAM from its slot by pushing outwards on the retaining clips.
  10. Dell Vostro 1700 RAM Replacement: étape 10, image 1 de 3 Dell Vostro 1700 RAM Replacement: étape 10, image 2 de 3 Dell Vostro 1700 RAM Replacement: étape 10, image 3 de 3
    • Lift the RAM chip up and out of the slot.
2 autres ont terminé cette réparation.
Nathan Valm
Membre depuis le 03/20/18
735 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G1, Peak Spring 2018 Membre de l'équipe UMass Dartmouth, Team S3-G1, Peak Spring 2018
UMASSD-PEAK-S18S3G1
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 15
Total : 1,091
